0 members (),
202
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 48 | I'm having detonation on acceleration issues with my 1950 3804. It has a 1956 235 bored .040 over freshly broken in rebuild with 2000 miles. I went 2 sizes up on the main jet but there's a lot of carbon in the exhaust and it still detonates. Still have the 5:14 rear. Maybe RPM's too high? Rochester NOS Model B early 235 carb #7002051. I have a Carter 2100 NOS carb and a NOS Stromberg BXVD-3 #380286 I can use if they are better carbs. Any ideas?
1950 3804 Pickup
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | My first guess is timing. Drive it to homecoming in April and we'll get it sorted out. Sweet has the magic touch and adjustable timing light to make it easy. | | | | | Joined: Feb 2004 Posts: 29,799 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,799 | Carbon in the exhaust- - - - -too rich. Lean it out at least halfway back to the original mixture. Find a LONG hill where you can run full throttle at normal cruising speed for 1/2 mile or more, without overspeeding the engine and listen for detonation- - - -"spark knock"- - - -whatever term you choose to use. It sounds like BB's rattling around in a tin can. Retard the timing a degree or two and repeat the uphill pull. Keep doing this until the rattle goes away, or at least can be stopped by easing up on the throttle position a little. That's what the "octane selector" was originally designed to do- - - -allow a driver to tweak the timing a little to compensate for differences in altitude and/or differences in the grade of gasoline from tank to tank. Jerry
| | | | | Joined: Dec 2006 Posts: 103 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 103 | Need a bit more info. This assumes that you have set your base timing to factory specs.
What did you have done with the heads?
Did they deck the block?
Do you know what your compression ratio is?
Do you have a temp gauge and where is it running?
Where is your base ignition timing set?
If the heads were milled and/or the block was decked, then it raised the compression. If you're above 9.5:1 you'll need to run mid grade or premium gasoline.
You might want to check the amount of mechanical advance in the distributor. If it advances too fast too far, it can give you problems. | | | | | Joined: Dec 2010 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 48 | Base timing at 0 degrees TDC
848 head with hardened valve seats for unleaded
don't know compression ratio or if head was milled or block decked, shop owner retired so no way to find out
temp gauge running at 180, 4 psi radiator cap, factory optional 5 blade heavy duty fan running ethanol free 92 octane fuel
IIRC the distributor is a NOS heavy duty truck option but I'll check part number
1950 3804 Pickup
| | | | | Joined: Dec 2010 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 48 | The detonation happens between cruising and opening up to WOT, mainly just as I'm pressing the pedal down. Maybe accelerator pump adjustment?
1950 3804 Pickup
| | | | | Joined: Dec 2010 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 48 | Hopefully I can make it to Homecoming. I'm planning on it
1950 3804 Pickup
| | | | | Joined: Feb 2004 Posts: 29,799 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,799 | Retard the total timing two degrees and you'll cure the problem. I'd change the centrifugal advance setting, but I've been tinkering with distributors for over 45 years and I know how to do it. Telling you how on the forum would be somewhere between difficult and impossible. Jerry
| | | | | Joined: Dec 2006 Posts: 103 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 103 | What Jerry said... Hey Jerry, just have him take a little off them weights with the bench grinder! LOL! | | | | | Joined: Feb 2004 Posts: 29,799 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,799 | Actually, it involves welding up the slots the weights move in a little, and re-curving the centrifugal advance- - - -used to do it on the round track cars all the time, but I had a Sun distributor tester and a delay-flash timing light. Jerry
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Sounds like the vacuum advance is advancing too much. Try running it with the vacuum adv. tube unhooked. If that is the case you can probably limit it with a machine screw in the slot. If you have the vacuum advance on manifold vacuum you could change it to ported vacuum. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
