5 members (baldeagle, Mike Roache, Gdads51, Hotrod Lincoln, Steelonsteel), 90 guests, and 2 robots.
Topics128,088
Posts1,055,993
Members48,430
#1206442 03/01/2017 4:24 PM
1 Offline
1950 Chevy 3100 series - Does anyone have pictures that show how the wiring should be routed from tail lamp to under truck? I was going to use the chromed wire loom cover but it doesnt look to have any means of actually attaching to the lamp body and not sure how it attaches to frame, box, etc on other end. Any input would be great! Thanks all!
1965t5 #1206481 03/01/2017 9:17 PM
Instructions on how to install the chrome conduit
Harold
Harold
1965t5 #1206531 03/02/2017 3:30 AM
Harold,
Thanks for the link to the Tech Tip.
Does the end in the lamp housing get crimped or glued/etc?
Where does the other end get positioned (is there a hole in the frame?
Thanks, again,
1965t5 #1206585 03/02/2017 4:22 PM
Does the end in the lamp housing get crimped or glued/etc? Use Silicone. There is no strain on the conduit.
Where does the other end get positioned (is there a hole in the frame? There are 3 (2 small, 1 large) holes in the side of the frame just before the bumper bracket bolts. Conduit goes through the larger hole. Rig up some sort of clamp (Tie Wrap, etc.) to hold the conduit in place.
Harold
Harold
1965t5 #1206588 03/02/2017 4:36 PM
Thanks, Harold
