Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (farmallb, TGP, 1955 1 Series, baldeagle, Dennys28, cmayna), 67 guests, and 3 robots.
Topics128,004
Posts1,055,265
Members48,418
#1206405 03/01/2017 4:22 AM
Z
Z Offline
My starter drive needs replacement. Is this a difficult job ?
Do I need to take apart the whole starter to get to the drive?
1953 chevy 1/2 ton with 3 speed 318 on floor and 1955 235 engine
Stomp start or solenoid-powered? Either way, the nose cone needs to be removed from the starter. You don't necessarily have to do a full teardown, but it might be a good opportunity to check the condition of the brushes and bushings, and replace them if necessary.
Z
Z Offline
Jerry, how is the nose cone held on ?
Two long bolts pass through from the rear plate and screw into the front housing. If you don't want to do a full teardown hold the main starter housing in a vise and carefully unscrew the through-bolts, but leave them in the field frame while you ease the nose cone and drive off the front. The shift lever will remove with the nose cone and take the drive with it. On a 12V starter, the drive splines on the armature are spiral, so the drive gear will rotate a little as it pulls off. If you pull the armature out of the brush assembly you'll need to do a full teardown to get them back into position.
Z
Z Offline
Thanks Jerry...The starter would not fit in my vise so I taped the back end on so it would not fall apart when taking the bolts out. ...worked perfectly...
This is great information- thanks Jerry. Any idea where to get a new 12V drive gear..? Are the gears different between the solenoid and stomp versions?
~ Dave
Not sure if we have the same type, but I documented my learning process with rebuilding the starter in THIS thread. Got lots of help from Jerry and others in the process. The pics might help you out.
I'm guessing this might end up in a different forum soon, though.
Best of luck,
Jim
1957 Chevrolet 3100 Stepside
235, 3-speed w/OD
