7 members (rfs56trk, Gray_Ghost, Wally / Montana, walter74, MRMEROTH11, David Bush, 1 invisible),
67
Mod | | | Forums66 Topics128,056 Posts1,055,803 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 76 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 76 | 1950 Chevy 3100 series - Does anyone have pictures that show how the wiring should be routed from tail lamp to under truck? I was going to use the chromed wire loom cover but it doesnt look to have any means of actually attaching to the lamp body and not sure how it attaches to frame, box, etc on other end. Any input would be great! Thanks all!
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Instructions on how to install the chrome conduit Harold
Harold Is a restoration ever finished? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Harold,
Thanks for the link to the Tech Tip.
Does the end in the lamp housing get crimped or glued/etc?
Where does the other end get positioned (is there a hole in the frame?
Thanks, again, | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Does the end in the lamp housing get crimped or glued/etc? Use Silicone. There is no strain on the conduit.
Where does the other end get positioned (is there a hole in the frame? There are 3 (2 small, 1 large) holes in the side of the frame just before the bumper bracket bolts. Conduit goes through the larger hole. Rig up some sort of clamp (Tie Wrap, etc.) to hold the conduit in place. Harold
Harold Is a restoration ever finished? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
