1 members (Hotrod Lincoln), 97 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#1204070 02/13/2017 1:49 AM
I have an 84 292 head that has egr ports.I want to eliminate the egr . cannot find plugs for these threads. they seem to be 11/16-18tpi. Next step is to drill and tap to 1/2npt. Is this the right move?
H Online: Content
1/2" is too big- - - -3/8" pipe plugs work very well, and if you use pipe plugs with Allen wrench holes instead of square heads the fix looks a lot better. There's no need to drill- - -just chase the existing threads with a 3/8 NPT tap. Tinker with the threading depth a little until the plugs tighten well just as they get flush with the head casting
thanks. will try it.
3/8 plug falls through the existing threads. there is enough room below the threads to tap for 3/8 pipe to get the plug closer to the exhaust port , which would be better anyway.
H Online: Content
Hmmmm- - - -interesting! I haven't encountered that type of head, apparently. Is it the one with the integral intake manifold? If so, have it magnaflux-checked for cracks before you invest a lot of time and money in it. They're notorious for warping and cracking.
Riding in the Passing Lane
That is the real late style. I have used a flare fitting on those & welded the opening up.
1972 Chevy c10 Cheyenne Super
it doesn't have the integral intake. its a 1984 crate motor, with jasper id on it. I bought it apart , and amazingly its std bore. Thinking of going w/a 4 bbl, and if I need heat for the intake, one of these ports would work well, I suspect. the 3/8 plugs are working well , down closer to the port, too. thanks for the help, Ed
