1 members (J Lucas), 85 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#1205213 02/21/2017 4:45 AM
Hi, does anyone have info on the 1/2 ton radiator support ?can't seem to find a diagram of how it is assembled to the frame pads and shims ?how many ? carriage bolt ? cotter pins?
thanks
41 Chevrolet 1/2 ton
Items needed to install radiator:
Hex Head Bolts 3/8" X 3" (2)
Washers 3/8" X 1 1/4 diameter (6)
Lock washers 3/8" (2)
Nuts for bolts (4)
Place bolt with washer through radiator support frame
DO BOTH BOLTS AT SAME TIME
Under support frame place both rubber pads on bolts
Next place bolts through frame
Next install washer (regular 3/8" washer)
Next install spring
Next install washer
Next install lock washer
Next install nuts & tighten to secure radiator mounting frame to chassis. Use extra nuts as lock nuts.
There are 4 small bolts (1/4" X 3/4") that bolt the top of the radiator support rod to the "bull nose" plate.
Parts Needed
Harold
Harold
ok great !! in your picture you have 4 nuts are these extra nuts to lock the others?
thanks
You are correct. I added the lock nuts to my first post.
Harold
Harold
