Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (MickeyP, ndkid275, crenwelge, 78buckshot), 145 guests, and 3 robots.
Topics128,284
Posts1,058,532
Members48,490
U
U Offline
I purchased an after market turn signal assembly for my 57. When engaging it, I have to hold the turn signal down or up while using it. It won't stay engaged
Anyway to fix it or should I order another? Would of course rather have an old NOS one.
Jon
1957 Chevy 1/2-Ton Truck
More pix
The coldest winter I ever saw was a summer I spent in San Francisco M. Twain
If at first you don't succeed...skydiving is not for you!
If you don't like my carbon foot print, stick it up your Prius!!
Bad unit, return it and get another (or a different brand).
Jon,
Had the same experience with an aftermarket "China made" turn signal switch. The plastic holding the internal spring was broken. Switch ended up in file "13." Spent the money on a Signal Stat switch which was more heavy duty and have had no problems. Learned my lesson again...Get what you pay for.
Tim
1970 VW Beetle
U
U Offline
Thanks guys!
More pix
