| | | Forums66 Topics128,268 Posts1,058,379 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | My stock 3 Speed is popping out of 1st and 2nd while going down a hill. I have a three on the tree on my 57 truck. On flat roads it does fine. Any thoughts on what the problem is? While retoring the truck I bought and had a shop rebuild the tranny. I only have 2000 miles on the truck since the resto.
Thank you.
Jon 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Poppet springs weak, thrust washer(s) missing or installed improperly, shift linkeage not adjusted properly, mainshaft or c'shaft bearings worn.
Ed
| | | | | Joined: Feb 2004 Posts: 29,947 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,947 | If the shift linkage is adjusted properly, you need to find another transmission shop and get them to fix what the first guy messed up. Don't bother going back to the first guy- - - -he's already proved what he can and can't do. Jerry
| | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Ed and Jerry are spot on with this tranny problem. Linkage,internal bearing wear, or a worn main shaft will cause the tranny to pop out of gear. Had an early Muncie 3 speed in my 1958 Chevrolet that would pop out of 3rd. Had a so called tranny shop rebuild it and it still did the same. Rebuilt it myself with all new bearings and main shaft, adjusted the linkage to FSM specifications and no more problems.
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Apr 2005 Posts: 2,103 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,103 | All of the above are causes. A worn front u-joint will also create problems. Popping out of 3rd gear is a common problem with these transmissions. There is a fix which places a spacer between the front bearing and the gear. You must also remove the spacer on the first row of needle bearings for this to work. This moves the gear further into the syncronizer. pre68Dave has info on this on his site also. Popping out of 2nd and 3rd indicates to me that all of the above could be in play. In any event a replacement syncro drum and the 2-3 shift fork are in order. Fred
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | My stock 3 Speed is popping out of 1st and 2nd while going down a hill. These transmissions almost never jump out of 1st or 2nd if the linkage is adjusted correctly.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2000 Posts: 734 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 734 | Rebuilt mine almost 40K miles ago, it's been fabulous except the column shifter has always shaked/bounced a lot in 2nd. Just keep a hand on it to steady it, and it's never acted like it wanted to pop out of gear. Probably could stand linkage adjustment?? but never stay in 2nd long enough to take my hand off the shifter, so never considered it much of a problem.
Matthew 6:33 1952 Chevy 1/2-ton 3100 Late '55 235/SM420/torque tube 3.55 Dalton Highway survivor (using original 216) www.truckwithaheart.com | | |
