7 members (2-Ton, Otto Skorzeny, tclederman, Bill Hanlon, Millenimech, dt235sd, greenie-reddy),
129
Mod | | | Forums66 Topics128,191 Posts1,057,365 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2017 Posts: 22 New Guy | | New Guy Joined: Jan 2017 Posts: 22 | Is it even possible to get new sheet metal metal fenders for these trucks? I don't want fiberglass, and I've got a couple fenders that are almost not worth the effort of patching. | | | | | Joined: Feb 2008 Posts: 1,124 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,124 | Andy Sometimes NOS fenders show up, but that is rare. As far as I know none are being produced as reproduction items, other than the fiberglass versions. There are or were some used ones listed for bid on eBay within the last week or so. | | | | | Joined: Jan 2017 Posts: 22 New Guy | | New Guy Joined: Jan 2017 Posts: 22 | | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | There is a pair on Ebay now! Harold
Harold Is a restoration ever finished? | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | There is a rear pair on Ebay now! Harold
Harold Is a restoration ever finished? | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Metal used front fenders are more available than the rears. At the time I couldn't find rears. If you go with fiberglass R&R Fiberglass gave me the best deal. Good luck with your search and have fun Dan | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | | | | | | Joined: May 2015 Posts: 11,181 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,181 | Is it even possible to get new sheet metal metal fenders for these trucks? I don't want fiberglass, and I've got a couple fenders that are almost not worth the effort of patching. But you'd be missing out on all the fun. I patched up both my AD rear fenders, including free forming a 6" x 12" patch panel for the rear portion that was rusted away, the mounting flanges, and a few other spots. Sometimes it's just what you have to do.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2017 Posts: 22 New Guy | | New Guy Joined: Jan 2017 Posts: 22 | That's true! I can do small patches, but the right rear will require re-doing almost the entire back half of the fender. I'm not sure I can form the metal into the original shape. | | | | | Joined: Jan 2013 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2013 Posts: 45 | Andy, I order my rear fender patches from a guy named Ray at [email protected] my rear fender need a lot of work including the rear of the fender which was gone, but he had all the stuff I need to fix them. He also has a lot of the patches for other area of the 41 - 46 truck send him a email and if you have a pictures of the fender showing all the bad area he can help. Good Luck Jerry
My first prewar and it will not be my last. Done with the 40 for my best friend. Got a 46 (year I was born) to build for me.
| | | | | Joined: Jan 2017 Posts: 22 New Guy | | New Guy Joined: Jan 2017 Posts: 22 | Hey thanks! I will definitely look into that | | |
