| | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 2 Moderated | | Moderated Joined: May 2015 Posts: 2 | Just a quick Hello from utah. I have been on this forum before as another username but I have decided to renew under a different username. I am in the beginning of opening a small shop (customs and classics) so I thought it would be wise to use a name that was more toward that goal. Although I have been a member here for a while I thought a fresh start would be wise. So here I am and I will probably still be mostly a Lurker. Thanks.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Welcome once again to the stovebolt. I hope you are "back" because you know what a great site this is. I'm sure you will have much to contribute as well as asking questions here. You probably also know there are quite a few guys and gals that hang around here from your Beehive state. Good luck on your venture. | | | | | Joined: Dec 2015 Posts: 2,062 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,062 | | | |
