| | | Forums66 Topics128,070 Posts1,055,892 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 127 | greetings, has anyone been able to free-up a windshield crank mechanism ? my gears don't appear to be stripped, rather stuck from sitting and possibly the steel shaft reacting to the aluminum housing. the bottom has a metal wedge thats pinned to the housing, and extends into the worm gear. if i drill out this pin and remove the wedge, will this free up the crank ?, or should this be sent in to rebuild ? thanks..
Just because you have a few Craftsman tools, it dosen't mean your a craftsman.
| | | | | Joined: Feb 2006 Posts: 5 Junior Member | | Junior Member Joined: Feb 2006 Posts: 5 | Hi Jeff, had the same proplem myself. Buy some KROIL OIL this stuff is the ticket. You can buy it from any leading tool and supply house.The greatest virtue is patience so let it do the work.This KROIL oil cost around $21.00 FOR A 16.5 OZ CAN little pricey but it works.You can get it in gallons to.Good luck | | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | you can order Kroil cheaper than that, directly from them! Made by Kano Industries, in Tenn..do a search on the web, and it should pullup their site. i have been using PB Blaster, seems to work okay too. Mike | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | I ended up taking mine completely apart. The brass thrust block had worn away and what was left wedged itself against the worm gear shaft. The spur gear shaft's axel had worn an elongated hole in the zinc die-casting. Have photos of the whole thing disassembled if you need. | | |
