2 members (carbking, RLB), 157 guests, and 2 robots.
Topics128,080
Posts1,055,954
Members48,430
#120432 04/30/2006 8:01 PM
greetings, has anyone been able to free-up a windshield crank mechanism ? my gears don't appear to be stripped, rather stuck from sitting and possibly the steel shaft reacting to the aluminum housing. the bottom has a metal wedge thats pinned to the housing, and extends into the worm gear. if i drill out this pin and remove the wedge, will this free up the crank ?, or should this be sent in to rebuild ? thanks..
Just because you have a few Craftsman tools, it dosen't mean your a craftsman.
#120433 04/30/2006 10:50 PM
Junior Member
Junior Member
Hi Jeff, had the same proplem myself. Buy some KROIL OIL this stuff is the ticket. You can buy it from any leading tool and supply house.The greatest virtue is patience so let it do the work.This KROIL oil cost around $21.00 FOR A 16.5 OZ CAN little pricey but it works.You can get it in gallons to.Good luck
#120434 04/30/2006 11:44 PM
you can order Kroil cheaper than that, directly from them! Made by Kano Industries, in Tenn..do a search on the web, and it should pullup their site. i have been using PB Blaster, seems to work okay too. Mike
#120435 05/02/2006 4:33 PM
I ended up taking mine completely apart. The brass thrust block had worn away and what was left wedged itself against the worm gear shaft. The spur gear shaft's axel had worn an elongated hole in the zinc die-casting. Have photos of the whole thing disassembled if you need.
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
