2 members (39Master85, 2Wheels),
105
Mod | | | Forums66 Topics128,196 Posts1,057,396 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2017 Posts: 22 New Guy | | New Guy Joined: Jan 2017 Posts: 22 | Can anyone tell me where to find the VIN or any kind of identification or characteristics that might help me verify the exact year of my pickup? Thanks! | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | There is no vin. The right hand side of the cab below the cowl had a plate. There are some numbers and letters stamped into that plate if still there. Also if the engine is original the numbers on the block will help. There are other hints. Does the gas filler neck have a leather seal or rubber seal. Two windshield wipers or one. How is the rear window installed. A bolted ring or just a rubber gasket? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Hello, Andy, Welcome to Stovebolt.com Click on each of the 1941-1946 truck links. http://chevy.oldcarmanualproject.com/chevyresto/index.htmClick on Unit Serial Numbers You will see SERIAL NUMBER LOCATIONS Decode your Vehicle Serial Number and Engine Serial Numbers And/or: post here your Vehicle Serial Number and your Engine Serial Number. | | | | | Joined: Jan 2017 Posts: 22 New Guy | | New Guy Joined: Jan 2017 Posts: 22 | I'll have to look and get back to ya | | | | | Joined: Jan 2017 Posts: 22 New Guy | | New Guy Joined: Jan 2017 Posts: 22 | Thanks, very helpful link | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Some more help here. Have fun and good luck Dan | | | | | Joined: Jan 2017 Posts: 22 New Guy | | New Guy Joined: Jan 2017 Posts: 22 | The number on the original engine block begins with DEA. From what I gather the "D" means it was a 46. It has a leather gas filler grommet, it has only one windshield wiper above the drivers side, and the rear window has a rubber gasket. | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | And the one I was looking for. Casting numbers on left side....I'm little slow today....lol Dan | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | My '47, first, GMC has numbers(EC) stamped in large letters outside of right framer rail half way between axle and front spring perch.
Ed
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | My '47, first, GMC has numbers(EC) stamped in large letters outside of right framer rail half way between axle and front spring perch.
Ed Chevrolets don't. | | | | | Joined: Jan 2017 Posts: 22 New Guy | | New Guy Joined: Jan 2017 Posts: 22 | | | | | | Joined: Feb 2008 Posts: 1,124 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,124 | The leather gas filler grommet would be an indication the truck was built fairly soon after the war ended. Mine has one too. It was born in June 1946. | | |
