6 members (3B, Gdads51, Tinker5, Bill Hanlon, Bills Auto Works, WICruiser), 141 guests, and 3 robots.
Topics128,195
Posts1,057,378
Members48,469
Can anyone tell me where to find the VIN or any kind of identification or characteristics that might help me verify the exact year of my pickup? Thanks!
There is no vin. The right hand side of the cab below the cowl had a plate. There are some numbers and letters stamped into that plate if still there. Also if the engine is original the numbers on the block will help. There are other hints. Does the gas filler neck have a leather seal or rubber seal. Two windshield wipers or one. How is the rear window installed. A bolted ring or just a rubber gasket?
Hello, Andy,
Welcome to Stovebolt.com
Click on each of the 1941-1946 truck links.
http://chevy.oldcarmanualproject.com/chevyresto/index.htm
Click on Unit Serial Numbers
You will see SERIAL NUMBER LOCATIONS
Decode your Vehicle Serial Number and Engine Serial Numbers
And/or: post here your Vehicle Serial Number and your Engine Serial Number.
I'll have to look and get back to ya
Thanks, very helpful link
Some more help here. Have fun and good luck
Dan
The number on the original engine block begins with DEA. From what I gather the "D" means it was a 46. It has a leather gas filler grommet, it has only one windshield wiper above the drivers side, and the rear window has a rubber gasket.
And the one I was looking for. Casting numbers on left side....I'm little slow today....lol
Dan
Crusing in the Passing Lane
My '47, first, GMC has numbers(EC) stamped in large letters outside of right framer rail half way between axle and front spring perch.
Ed
Ed
Chevrolets don't.
I see
The leather gas filler grommet would be an indication the truck was built fairly soon after the war ended. Mine has one too. It was born in June 1946.
