0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
#1203721 02/10/2017 4:10 PM
I realize that this has probably been covered - but - the search brings up thousands of results....So - where can I get a GOOD set of bits (or drivers) for these clutch head bolts?
DLBrooks
DLBrooks
try Amazon -- quality may be differentiated by pricing --usually 4 bit size kits
1959 GMC 100 Fleet
Follow in the DITY
Napa also sells good tools.
Second Joe H.
shake
I bought a set on eBay for about $10 that I am very happy with. I bought ones that fit into a 3/8" ratchet and are about 3" long. The end that goes into the ratchet is knurled, so it makes it easy to snug or loosen with your fingers when the bolts are loose.
I learned a tip from another 'bolter that I'll pass along. If you buy a set as described above and run into a frozen clutch head screw or bolt, use a hand impact driver to get it out. These are the impact drivers that you whack with a hammer. It was a great tip and it usually works. Much better than my old technique of cutting slot with a Dremel to fit a large flat screwdriver blade into the head.
Matt
Ex Hall Monitor
Ex Hall Monitor
I've found that if the screw isn't rusted in place a regular slot head screwdriver works just fine.
I purchased a set on Amazon for around $20. They came in a set of four different sizes. They worked well for my purpose.
1950 3100 5 Window
http://imgur.com/a/DAVYB
I have to remove my front door hinges and will use this technique. I will probably use some heat as well
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
Ok, thanks! The nearest NAPA is about 60 miles away, so that's not an option! Probably go the "Amazon" route....What sizes do I need? I DO know one thing - when I get them out, they're gonna be replaced with a REAL bolt!
You can buy them in the regular screwdriver handle format or to be used with a 3/8 ratchet. I think I bought mine from one of the truck part vendors.
1951 1 Ton Completed
Dachshund, after you get them out don't throw them away. There are people out there who want them for originality.
just type clutch head bolts on ebay, I got mine there
1961 apache
Moderated by  MNSmith
