10 members (Wayne67vert, Bill Hanlon, moparguy, Phak1, Oswald, Rusty Rod, TUTS 59, 3 invisible),
73
Mod | | | Forums66 Topics128,089 Posts1,056,005 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2017 Posts: 5 New Guy | | New Guy Joined: Feb 2017 Posts: 5 | Can anyone help in identifying my engine? Casting number appears to be 894258. The number next to the distributor is 1211TGA. Can't find the number in my table. I think it is 292? Top | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | If it has tall side covers over the lifters(behind the dist.) it is a 292.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | About 6" tall, rather than about 4"l worth searching for.
Ed
| | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | Simple way to identify a 292- - - -the motor mounts are offset about 3" side to side. 194, 230, and 250 have mounts that are straight across from each other. Jerry
| | | | | Joined: Feb 2017 Posts: 5 New Guy | | New Guy Joined: Feb 2017 Posts: 5 | Yes, the lifter covers are 6 inches tall, so that makes it a 292. Do the numbers tell anyone what year it is? Are the points, plugs , condensor, rotor and cap the same for all 292's? Is the tune up specs the same?
Thank you for all your help. | | | | | Joined: Nov 2016 Posts: 9 New Guy | | New Guy Joined: Nov 2016 Posts: 9 | 292 has a bypass hose from the thermostat housing to the water pump.None of the other sixes have it. | | | | | Joined: Sep 2011 Posts: 1,453 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,453 | 292 has a bypass hose from the thermostat housing to the water pump.None of the other sixes have it. Later 261 have thermostat by-pass hose but also 1 side cover v.s. 2 on 194 / 230 250 292.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Found this # 3994258 , 1967-90 292 | | | | | Joined: Feb 2000 Posts: 5,210 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,210 | Since the 292 spans a long life, tune up spec's probably changed over the years. Actual parts most likely stayed the same. In the late 70's they swapped over to HEI ignition, and probably to a later ignition before the last of them in the 90's. Early on, the 230-250-292 all used the same head so date codes are hard to pin down. They used the same block for years, so again dates are hard to pin down. At some point, they switched heads to one with the intake cast into the head. These tended to crack, so swap to an older style if that is the case. I would probably start with '71 or '72 spec's, thats right before the unleaded changes and heavy smog equipment was installed. Since modern fuel is quit different from when the engine was designed, factory spec's are only used for a starting point. Tune the engine for high vacuum and the most timing it can take without detonation under a load.
Just to be sure it's a 292,
side motor mounts, staggered side to side, passenger forward, dr side mid engine fuel pump mid engine, passenger side push rod covers, two, about 6" tall, three bolts each Rocker cover, 7 bolts 63-66, 7/16" flexplate/flywheel bolts 67-90, 1/2' flexpalte/flywheel bolts
Go back and look at the casting number, 3994258 is a 292 | | | | | Joined: Feb 2017 Posts: 5 New Guy | | New Guy Joined: Feb 2017 Posts: 5 | [quote=JiMerit Boltr#43]Found this # 3994258 , 1967-90 292[/quote]
Yes, that is the number. Had to clean it up to make out it was an "3" and not an "8". Thanks for the help.
| | | | | Joined: Feb 2017 Posts: 5 New Guy | | New Guy Joined: Feb 2017 Posts: 5 | Okay, cleaned the numbers and it is 3994258. Thanks for all your help.
