2 members (3B, Cosmo), 149 guests, and 3 robots.
Topics128,080
Posts1,055,951
Members48,430
Can anyone help in identifying my engine? Casting number appears to be 894258. The number next to the distributor is 1211TGA. Can't find the number in my table. I think it is 292?
Top
If it has tall side covers over the lifters(behind the dist.) it is a 292.
Tommy
59 apache 1/2t
261 short stepside
Crusing in the Passing Lane
About 6" tall, rather than about 4"l worth searching for.
Ed
Simple way to identify a 292- - - -the motor mounts are offset about 3" side to side. 194, 230, and 250 have mounts that are straight across from each other.
Yes, the lifter covers are 6 inches tall, so that makes it a 292. Do the numbers tell anyone what year it is? Are the points, plugs , condensor, rotor and cap the same for all 292's? Is the tune up specs the same?
Thank you for all your help.
I
I Offline
292 has a bypass hose from the thermostat housing to the water pump.None of the other sixes have it.
Later 261 have thermostat by-pass hose but also 1 side cover v.s. 2 on 194 / 230 250 292.
BC
1960 C60 pasture art
Found this # 3994258 , 1967-90 292
1946 1/2-Ton Chevy
Since the 292 spans a long life, tune up spec's probably changed over the years. Actual parts most likely stayed the same. In the late 70's they swapped over to HEI ignition, and probably to a later ignition before the last of them in the 90's. Early on, the 230-250-292 all used the same head so date codes are hard to pin down. They used the same block for years, so again dates are hard to pin down. At some point, they switched heads to one with the intake cast into the head. These tended to crack, so swap to an older style if that is the case.
I would probably start with '71 or '72 spec's, thats right before the unleaded changes and heavy smog equipment was installed. Since modern fuel is quit different from when the engine was designed, factory spec's are only used for a starting point. Tune the engine for high vacuum and the most timing it can take without detonation under a load.
Just to be sure it's a 292,
side motor mounts, staggered side to side, passenger forward, dr side mid engine
fuel pump mid engine, passenger side
push rod covers, two, about 6" tall, three bolts each
Rocker cover, 7 bolts
63-66, 7/16" flexplate/flywheel bolts
67-90, 1/2' flexpalte/flywheel bolts
Go back and look at the casting number, 3994258 is a 292
[quote=JiMerit Boltr#43]Found this # 3994258 , 1967-90 292[/quote]
Yes, that is the number. Had to clean it up to make out it was an "3" and not an "8". Thanks for the help.
Okay, cleaned the numbers and it is 3994258. Thanks for all your help.
