Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (baldeagle), 53 guests, and 1 robot.
Topics128,003
Posts1,055,244
Members48,418
#12034 11/29/2004 4:24 PM
I installed some Blue Streak points in my 64, they have a small wick which rides on dist cam instead of a capsule of grease. I soaked it w/motor oil. Is this correct & how often would you re-oil? Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#12035 11/29/2004 5:39 PM
Most points came with a small gel capsule of high-temperature grease. The oil won't stay put well enough. DB-rated wheel bearing grease makes a good substitute if the capsule was missing. Just coat the distributor cam sparingly, and let the felt wiper spread it. The points will fail before you need to re-lube it.
