4 members (TexasJim50, 1955 1 Series, Otto Skorzeny, RLB), 55 guests, and 1 robot.
Topics128,154
Posts1,056,851
Members48,456
#120288 04/14/2006 7:17 PM
trying to fix my door latches but ican't even get the outside door handle off. can anyone reccomend a good book that covers door and window mechanisms or do ijust need a bigger hammer?? the truck is a 40. thanks and happy easter.
Just because you have a few Craftsman tools, it dosen't mean your a craftsman.
#120289 04/14/2006 8:28 PM
I went to
http://www.haist-usa.com/artdecotrucks/ go to the links and select American Classic Truck Parts and search by the year of your truck.
They have a door handle ferrule tool that runs around $33.00 you may find it elsewhere for a better price. From what I have been reading you need this to remove and replace the door handles. Hope this helps
Ed
#120290 04/14/2006 11:30 PM
Wahoo40 - If you are just trying to remove the door handle you won't need the ferrule tool. There is a screw on the inside of the door that goes into the end of the door handle stem. Take that screw out and the handle should slide right out. There is nothing else holding it on. You shouldn't even have to take the interior door pannel off.
If it doesn't slide out you'll need to get some PB-Blaster or Liquid Wrench in there to loosen up the rust.
Good Luck
George
#120291 04/14/2006 11:43 PM
thanks for the reply, yes i took that screw out but the handle won't come out. i soaked it good with pb blaster and i'll let it sit overnight. i was getting thirsty anyway. i know the return spring in the latch is broken, hopefully ican get it apart and put in a new spring. thanks again.
#120292 04/26/2006 7:29 PM
If you need photos of the stuff that is cleverly hidden inside of the door let me know. I have the driver's side door on my '41 all apart.
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
#120293 04/30/2006 7:23 PM
thanks for the offer kip, but i got the latches figured out and working fine. now i'm on to trying to repair the shelf ?? that the windshield hinges bolt to. there was a mouse nest up there and it's a mess. trucks are fun!!
#120294 05/01/2006 12:33 AM
Been there, done that. I have also found one behind the left headlight. My hinges were jamed but only took a little WD 40 to fix
