| | | Forums66 Topics128,113 Posts1,056,618 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 127 | trying to fix my door latches but ican't even get the outside door handle off. can anyone reccomend a good book that covers door and window mechanisms or do ijust need a bigger hammer?? the truck is a 40. thanks and happy easter.
Just because you have a few Craftsman tools, it dosen't mean your a craftsman.
| | | | | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | I went to http://www.haist-usa.com/artdecotrucks/ go to the links and select American Classic Truck Parts and search by the year of your truck. They have a door handle ferrule tool that runs around $33.00 you may find it elsewhere for a better price. From what I have been reading you need this to remove and replace the door handles. Hope this helps Ed | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Wahoo40 - If you are just trying to remove the door handle you won't need the ferrule tool. There is a screw on the inside of the door that goes into the end of the door handle stem. Take that screw out and the handle should slide right out. There is nothing else holding it on. You shouldn't even have to take the interior door pannel off. If it doesn't slide out you'll need to get some PB-Blaster or Liquid Wrench in there to loosen up the rust. Good Luck George | | | | | Joined: Apr 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 127 | thanks for the reply, yes i took that screw out but the handle won't come out. i soaked it good with pb blaster and i'll let it sit overnight. i was getting thirsty anyway. i know the return spring in the latch is broken, hopefully ican get it apart and put in a new spring. thanks again.
| | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | If you need photos of the stuff that is cleverly hidden inside of the door let me know. I have the driver's side door on my '41 all apart. | | | | | Joined: Apr 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 127 | thanks for the offer kip, but i got the latches figured out and working fine. now i'm on to trying to repair the shelf ?? that the windshield hinges bolt to. there was a mouse nest up there and it's a mess. trucks are fun!!
| | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Been there, done that. I have also found one behind the left headlight. My hinges were jamed but only took a little WD 40 to fix | | |
