| | | Forums66 Topics128,109 Posts1,056,268 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2016 Posts: 170 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 170 | Has anyone ever thought about laying some strut channel down in their bed between their 2x8 (or whatever) boards? I was just thinking it could come in handy for randomly bolting down anchors, attachments, etc. They have slotted ones that could help dirt and water fall out the backside. They'd probably be reasonable cheap if obtained from a plumbing or electrical wholesaler as opposed to the hardware store. https://www.lowes.com/pd/SUPERSTRUT...lated-Half-Slot-Channel-Strut/1000192655 | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | interesting idea, would have to give it some more thought. I guess it depends on what you are hauling, I would rather tie down with straps hooked ones the outer rail so you are not relying on a bolt and that rail to handle the load. Also, if you haul dirt, it would fall through, and if hauling gravel, you might get some stuck in the slots. | | |
