2 members (ChevyBlue, Otto Skorzeny), 224 guests, and 8 robots.
Topics128,077
Posts1,056,033
Members48,433
#1201342 01/25/2017 3:44 PM
First of all, my 3600 rides and drives fine. I've gone to 215/85/16 radial tires and it has a steel Clark flatbed with low mileage shocks at all corners.
The problem is the 65 year old springs have sagged a bit, making the truck set lower than I like. Now I realize the softer than l like suspension along with the flat beds weight does contribute to the nice ride but it just doesn't look right for a 3/4 ton.
Not wanting to totally screw up the suspension/steering geometry I'm NOT even considering flipping the front axle, but I am thinking about making up some 3" or so blocks for both ends.
On the rear I'm considering air bags for the occasional load of fire wood or hay. If I go with a pair of bags, then no blocks in the back.
New springs or have the existing tired springs re-arched is currently not on the table.
Any comments on how much lift I can add without making it a bear to drive are appreciated. I do realize adjustments will have to be made with even a mild lift.
Thanks, Ron
RonR
1970 340 Duster
1964 CJ5
The simple fix would be to add a leaf or two to the spring pack on both sides of the front. Adding rear leaves will make the rear end very bouncy when unloaded, so air bags might be a better choice back there. You might need longer U bolts, depending on how much thread is left sticking out of the nuts at the moment. You'll definitely need to replace the center bolt in the spring, since there's usually no extra length available there.
If you change the ride height enough to get the drag link out of level, be prepared for bump steer problems. That gets into e$$$pensive modifications of the steering gear position.
Fox Offline
Ron,
When I replaced the front leaf packs in my 1 ton it picked up the front end 2"! The springs were sacked out. Broken, cracked, flat. It really changed the look of my truck when I replaced them and that was with new custom built to stock specs springs. It's a viable option if you're concerned about geometry and such. Plus, just parking a big old brute beside a 1/2 ton will get attention at the shows! I know mine does. 😉
Mind you, I haven't completed mine yet, nor have I driven it since I replaced the springs. I suspect it's going to ride like a brute too 😕
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Blocks on the rear would be ok, but you NEVER want to put blocks on a front axle. Too much stress involved with the steering.
Bill Burmeister
I took my leaf springs to local 'old school' spring shop, first thing per the expert was to make a new main leaf, which helped a lot. I'd also consider a pair of air schocks in the rear, that way you can add or subtract the air charge as you need.
Good luck
1946 1/2-Ton Chevy
If you're interested, St. Louis Spring (St. Louis, MO) does a good job making new springs to spec and for a good price. I've used them and was very satisfied.
Samantha
1954 Chevy 3100
Picked from the Field
Follow in the DITY
Well, seems that little nagging voice that lives in the background was right, blocks are easy but far from the best solution.
Plan now is bags in rear, spring work for the front. I'll work on the exact spring plan as I get closer to moving back into the shop. The past several weeks have been devoted to working in/on the house.
RonR
1970 340 Duster
1964 CJ5
I'm adding Spring Assisted - Shocks Good for Leveling Up and taking an Inch of Sag Out . The Spring Assisted give an Inch of Light Spring Travel good for all those sudden Dips ans Ripples in road - which are Jarring with Old Flat Springs about Bottomed out .
Your life is made up of Two Dates and a Dash........make the most of the Dash.
http://www.fossilcars.com/chevrolet/1-ton-pickup/869217
