0 members (), 109 guests, and 2 robots.
Topics128,167
Posts1,057,021
Members48,458
I have replaced the Huck brakes on my '47 3100 with Bendix style from a '58 GMC. In the process of removing the brake assemblies from the '58 I twisted off one of the 1/2" bolts that goes thru the steering knuckle and backing plate. Does anyone know of a source for these or should I just use any grade 8 bolt?
I did mine last year, (1951 3100), replaced all of this with Grade 8 stuff. These bolts are just a standard bolt, most probably what came out wasn't G8, but they are not a special designed bolt, if that's what you're asking.
Mike
Mike
1951 3100 5 window
That answers my question thanks.
H Online: Content
Be sure the unthreaded bolt shank extends all the way through the steering arm, or very close, even if you have to add a shim or a couple of flat washers to allow the nut to tighten.
