6 members (Tom McGrath, 32Fordpuchoptop, Otto Skorzeny, Gdads51, Wickedbass, 1 invisible), 94 guests, and 2 robots.
Topics128,094
Posts1,056,051
Members48,433
#1202549 02/01/2017 10:09 PM
after taking the rusted floor, inner and outer cowl and kick panels out for repair or replacement and reassembly. its time to put the inner and outer fenders back on. should I mate them together and then install or do them separately. thank you, brian
1955 First series 3600 3/4-ton
"A Great Starting Point"
Follow the story and pix in the DITY Gallery
66flea #1202564 02/02/2017 12:24 AM
Year?
66flea #1202566 02/02/2017 12:28 AM
55.1 3600
66flea #1202567 02/02/2017 12:30 AM
the grill is coming off next and I was wondering if I could do tem as on piece
66flea #1202574 02/02/2017 12:53 AM
them as one piece
66flea #1202604 02/02/2017 3:25 AM
Are you asking if the entire assembled front clip (fenders, inner fenders, grill) can be installed as one piece?
The answer is yes. Good luck not scratching up the paint, however.
Carl
66flea #1202619 02/02/2017 6:02 AM
Fox Offline
I am curious about reassembly procedure. I know that during mockup on my GMC 53 1 ton that it was kind of a pain to install the inner and then the outer. You have to slip the outer fender under the rad support, over the inner fender and outboard of the cab. Good luck not scratching paint doing that. It proved a real PIA despite having everything super loose.
In the other hand, I assembled the clip (minus grille and surround) and it seemed easier. But if it were painted I would want about 4 people helping me sloooowly attach it. Plenty of masking would be required to help prevent scratches.
Anybody have opinions, ideas, tips on how to assemble a painted front end best?
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
66flea #1202706 02/03/2017 1:40 AM
That is what they make touch up paint for. You are going to scratch the paint. Most of it will not show if you can go slow and have good help.
