3 members (cmayna, tclederman, 1 invisible), 121 guests, and 1 robot.
Topics128,134
Posts1,056,402
Members48,441
#1199750 01/15/2017 4:47 AM
Hi guys, I am putting in a chassis engineering IFS in with their motor mounts and trans mount. I am going to put in a small block chevy motor. Has anyone else done this. My question is will an HEI distributer fit up against the firewall? will there be enough clearance? or should I order a smaller body distributer when I order the engine. Thanks for the help ahead of time
Hey Mikes54, We have a 5.7l from a wrecked iroc camaro in a '54 3100. couldnt use the HEI that came with the motor, too big. we have a skinny MSD with an AL6 box. the one we have is 4" vice the 6" HEI. I am interested to hear where you go with yours. Cheers.
Mike, if you are going to order the engine just order the smaller distributor. That way you know you will be ok.
Thanks for the info guys
Going automatic? A side mount bellhousing will let you bolt the small block to your manual trans. Just need to add front mounts to small block.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
