3 members (NorCal52Suburban, klhansen, delky), 58 guests, and 1 robot.
Topics128,090
Posts1,056,024
Members48,430
#1202420 01/31/2017 11:52 PM
I am considering buy a 235 which have the numbers 3769716. Inliners say this is an 58-62 year(s). What I would like to know are what these other letters/numbers indicate: CON4-K90 GM22 or a link to visit. Thanks Steve
CON4 means that it was made on conveyor 4 at the foundry.
K90 is the date code. K is the 11th letter, so that corresponds with the 11th month, November. 9 is the day of the month. 0 is the last digit of the year, so 1960. Your engine was built on November 9, 1960.
Matt
Thanks Matt. I believe most of these engines were made in Flint Mich. Steve
If someone can help. I have a 46 1.5 tone the numbers on the block are ADEA2I5380 is this the corect motor? found 235 on the oil pan Thanks
Rocky N,
Post all the codes shown on this page.
They should help in id-ing your engine.
Rocky N, That 235 pressed into the oil pan is a great find, most miss it as usually covered in crud.
1946 1/2-Ton Chevy
The difference in the "235" pan on the splash-oiler engines is the height of the dipper troughs- - - -the longer stroke of the 235 engine necessitates that the troughs be placed lower in the pan.
I find it interesting Chevrolet sold a replacement pan that is listed to fit "1940-53 all"(216-235), except 1953 full pressure 235.
My Blog
