0 members (),
139
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,113 Posts1,056,619 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 13 New Guy | | New Guy Joined: Nov 2005 Posts: 13 | Bolters;
I'm in the process of rebuilding a 302 to install in my '53 GMC pickup. I think I'd like to set it up for an air conditioning unit as well. Does anyone who has done this before have any recommendations/lessons learned they might share with me?
My specific question right now concerns the best way to mount the compressor and alternator. Should I get a two-groove harmonic balancer, or just stay with the single groove and run the alternator off the compressor pulley? Does anyone make brackets, or will I need to fabricate my own?
Thanks; Joe Midland, TX | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I think Patrick has one if you can get him to produce in a timely fashion.
Ed
| | | | | Joined: Nov 2005 Posts: 13 New Guy | | New Guy Joined: Nov 2005 Posts: 13 | Thanks, Ed. I happened to be near Casa Grande for work and stopped in to see Patrick. He's been in the hospital and is still recovering. Spoke to Danese and she helped me out. I had the mounts in a week. Price was cheaper than anything else I had found as well. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I made a mount for compressor in the generator location kept single belt. Mounted a small alternator directly above the compressor (another home made bkt), used a second and shorter belt connecting compressor to alt. Took some tweaking to get t right but simple solution. Also there are kits just for this, Alan Drake I believe has all kinds, do a Google search. Hope Patrick is ok! Last couple items I tried to purchase were so far back ordered I gave up. Glad you got the bkts from Denise Best of luck
