9 members (dt235sd, Jon G, Gdads51, mick53, 4tttt8, Leo, Otto Skorzeny, TUTS 59, 1 invisible), 87 guests, and 5 robots.
Topics128,181
Posts1,057,177
Members48,465
#1202064 01/29/2017 7:00 PM
Z
Z Offline
When installing new flywheel to crank bolts should I lube them ???
1953 chevy 1/2 ton with 3 speed 318 on floor and 1955 235 engine
Do not lube those bolts. Thread chase the holes and clean the threads on the bolts. A minuscule amount of anti-seize will keep them from rusting to the crankshaft for easier removal in the future. Tighten to the proper torque spec.
Tim
1970 VW Beetle
I'd suggest blue Loctite- - - -it lubes the thread for assembly and then cures to prevent any possibility of loosening. Red needs to be heated to release it on disassembly, blue just needs a good 6 point socket to break the bond.
Those mount holes go all the way through the crank, they are not blind holes. They should be installed with some kind of sealant after cleaning the bolts and the holes if not you could get an oil leak, the oil could wick up the bolt threads. Like Jerry said blue loctite will work it will also seal the threads from leaking oil.
1962 GMC 920 step side 261 4 spd
