| | | Forums66 Topics128,172 Posts1,057,105 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2016 Posts: 246 | When installing new flywheel to crank bolts should I lube them ???
1953 chevy 1/2 ton with 3 speed 318 on floor and 1955 235 engine
| | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Do not lube those bolts. Thread chase the holes and clean the threads on the bolts. A minuscule amount of anti-seize will keep them from rusting to the crankshaft for easier removal in the future. Tighten to the proper torque spec.
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | I'd suggest blue Loctite- - - -it lubes the thread for assembly and then cures to prevent any possibility of loosening. Red needs to be heated to release it on disassembly, blue just needs a good 6 point socket to break the bond. Jerry
| | | | | Joined: Jun 2015 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2015 Posts: 59 | Those mount holes go all the way through the crank, they are not blind holes. They should be installed with some kind of sealant after cleaning the bolts and the holes if not you could get an oil leak, the oil could wick up the bolt threads. Like Jerry said blue loctite will work it will also seal the threads from leaking oil.
1962 GMC 920 step side 261 4 spd
