0 members (),
170
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2016 Posts: 5 New Guy | | New Guy Joined: Dec 2016 Posts: 5 | Hi guys, I am putting in a chassis engineering IFS in with their motor mounts and trans mount. I am going to put in a small block chevy motor. Has anyone else done this. My question is will an HEI distributer fit up against the firewall? will there be enough clearance? or should I order a smaller body distributer when I order the engine. Thanks for the help ahead of time | | | | | Joined: Mar 2016 Posts: 7 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 7 | Hey Mikes54, We have a 5.7l from a wrecked iroc camaro in a '54 3100. couldnt use the HEI that came with the motor, too big. we have a skinny MSD with an AL6 box. the one we have is 4" vice the 6" HEI. I am interested to hear where you go with yours. Cheers. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Mike, if you are going to order the engine just order the smaller distributor. That way you know you will be ok.
| | | | | Joined: Dec 2016 Posts: 5 New Guy | | New Guy Joined: Dec 2016 Posts: 5 | | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Going automatic? A side mount bellhousing will let you bolt the small block to your manual trans. Just need to add front mounts to small block.
