| | | Forums66 Topics128,151 Posts1,056,994 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 331 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 331 | Fixing to start overhauling my 261, I'm planning to step it up a few notches. I want to run dual carbs on it but I don't have any idea what carbs I need to start looking for. Any help would be much appreciated.
Planning to raise the compression a bit (not too high - 9ish), change the cam and put dual exhaust on it.
1950 4100 - unrestored and driven weekly for almost no reason at all.
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | 2 stock Carter 1 bbl. originally used on the 216 is a safe choice. | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | you might consider upgrading the camshaft also. | | | | | Joined: Jan 2008 Posts: 360 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 360 | my reference info for zenith carbs comes from the carburetor shop files http://www.thecarburetorshop.com/TruckkitsG.htm#TkitGMCand other files on his site. any model zenith that is specific to the 248 engine will work, obviously w/ some exceptions like the alcohol carb and a few others.
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | dual carbs?
You might not want to use two Zenith carbs from 248 engines. You might be better off trying two Zenith carbs off of 228 GMC engines.
Also, maybe someone will post info on an adjustable main jet for those carbs?
| | | | | Joined: Oct 2013 Posts: 331 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 331 | you might consider upgrading the camshaft also. Yes, I stated that.
| | | | | Joined: Feb 2000 Posts: 5,232 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,232 | I run two Carter W-1's ( 1941 #483 ) on my 250 inch inline with no problems. It takes lots or trial and error to get duals set right. Plan on plenty of test drives and a lot of fine tuning. Once they are set, you are good to go just as you would be with any single carb. | | | | | Joined: Oct 2013 Posts: 331 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 331 | Thanks for the input. I have lots and lots of experience with multiple carburetor setups so getting them sync'd should not be an issue for me. I just needed to know what to look for on this particular application. I haven't decided for sure just yet, but I may end up just making my own intake and running a single 2-barrel. We'll see.
| | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | I must have been daydreaming,sorry .LOL | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I am now running a GMC 302's Holley AA-1 2-barrel with adjustable main jets on my 261. It is the best carburetor configuration that I have tried on it since I rebuilt this 261 engine in 1972. | | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | What kind of manifold does the 2 barrel sit on?
1951 3100
| | | | | Joined: Nov 2002 Posts: 2,767 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,767 | If the carbs are properly selected and adjusted; and the intake is decent, then the duals will give a bit more performance; albeit at higher cost, and more time.
One needs to look at all aspects of the engine, especially target RPM when selecting the carbs.
A single two-barrel will be somewhat easier to select, certainly less expensive, than the duals.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Oct 2013 Posts: 331 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 331 | What kind of manifold does the 2 barrel sit on? A homemade one.
| | | | | Joined: Oct 2013 Posts: 331 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 331 | If the carbs are properly selected and adjusted; and the intake is decent, then the duals will give a bit more performance; albeit at higher cost, and more time.
Jon. Yeah, I have about 7 different Rochester 2-jets in my possession that I could choose from. I have always had good luck with those carburetors. Really the only reason I am even considering a dual setup is just for curb appeal whenever I open the hood for curious onlookers. lol The truck draws lots of attention wherever I drive it.
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | I'm not sure that a modified original manifold, or same with adapter using a 2 bbl. will have the same cylinder-to-cylinder mixture distribution as stock. This is also true of the 2 X 1 manifolds: most including Edelbrock, Offenhauser etc. have the carbs centered in the inter-port distance, but others including Fenton have the position biased to the end cylinders. I suspect the latter is a better choice.
If choosing carbs or a manifold for 2 X 1, the size you want has the SAE #2 2-11/16" bolt pattern. The SAE #3 2-15/16" pattern is best for larger engines and higher RPM. | | | | | Joined: Nov 2002 Posts: 2,767 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,767 | The configuration of the intake manifold is as important as the choice of carburetors; as the air/fuel mixture MUST pass through the intake to get to the cylinders.
No actual test data to back me up, but I would (opinion) certainly agree with Panic about the bias to the end cylinders being superior to bias to the center.
There is test data to support this on dual quads on Pontiac V-8's.
If doing a homemade intake, remember that the air/fuel mixture delights in traveling in a straight line and hates going around corners. Also that runners to each cylinder should be as close as possible to the same length.
As to a 2->1 adapter; the results of testing we have done (and we have done quite a bit on this subject) have ALWAYS been uniform.......regardless of what 2 barrel may be used, it NEVER worked as well as the single barrel it replaced. Think NASCAR restrictor plate.
