4 members (Hanks custodian, klhansen, Peggy M, 1 invisible), 123 guests, and 2 robots.
Topics128,052
Posts1,055,727
#1199430 01/12/2017 8:33 PM
Can I install the brake line across the bell housing support cross member with the engine and tranny in place? Any observations on stainless brake line installation, thanks
Jcb3 #1199480 01/13/2017 2:38 AM
Is that a removable cross member? If so I wouldn't cross there. I thing Chevrolet ran the line under/behind the front cross member.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B #1199563 01/13/2017 6:48 PM
On my 4t6 3/4 ton the brakeline runs from master cylinder across the rear of bellhousing crossmember to a front and rear junction. Hope this helps. Have fun and good luck
Dan
Chev4t6 #1199781 01/15/2017 3:08 PM
Found this picture that may help a little. You can see the brake line at the very bottom.
Dan
Jcb3 #1199793 01/15/2017 4:42 PM
Great pictures! I copied some for for my project. Can you remember how the radiator support frame connects to the frame? Specifically if there are plates and rubber gaskets between the frame and support bracket, and what order they go.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
Jcb3 #1200132 01/17/2017 9:48 PM
V
VEW Offline
V Offline
MikeE, as I recall, there are two rubber gaskets: one on each side of the radiator support at the bottom. There's a plate on that goes on top of the gasket inside the radiator support. Two bolts (carriage I believe) go through the plate, radiator support, and frame.
~ Victor
1957 3100 - moved on
Jcb3 #1201422 01/25/2017 10:05 PM
Just a heads up on the spacers under the radiator. The placement of the radiator on the 41-46 trucks determines much of how the sheet metal seams will look on the hood to cab, hood to fenders/fender extensions and hood to grill pieces. I had the pleasure of having to remove a number of these pieces and reposition the radiator to get my seams more or less even.
Jcb3 #1201438 01/25/2017 11:49 PM
VEW, Mick,
Thanks, have to find that stuff and figure out how to line it up correctly..
1946 1-ton Panel
Jcb3 #1201441 01/26/2017 12:13 AM
Mike,
See my post dated 4/16/16 for detailed instructions of mounting the radiator SUPPORT FRAME
Harold
Harold
