0 members (),
361
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2017 Posts: 50 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 50 | I just purchased this truck on ebay and can't wait for delivery. I was decoding the VIN (SW54K025843) and the SW denotes a 6400 Special which the specifications manual seems to call a 1 1/2 Ton with a GVWR of 15,000 lbs. The regular 6400 is shown as a 2 Ton with a GVWR of 16,000 lbs. I thought the 4000 series was the 1 1/2 ton series and the 6000 series was the 2 ton series. What (and why?) is a 6000 series 1 1/2 ton? 23 Pictures - http://s1042.photobucket.com/user/58limited/library/1954 Chevy 6400
1953 Chevy 3100 Pickup 1954 Chevy 6400 Grain Truck 1957 Pontiac Transcontinental 1958 Buick Limited 2 Dr 1968 Ford Galaxie 500 1974 Ford F-350 Flat Bed (Dump Bed), former Pioneer Seed Truck.
"Beer is proof that God loves us and wants us to be happy." ~ Benjamin Franklin
| | | | | Joined: Jan 2017 Posts: 50 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 50 | Yes, that is where I found the info in my original post above. Just curious as to why some 6400 models are 1 1/2 ton specials when Chevy had a 1 1/2 ton series - the 4000 series.
| | | | | Joined: Sep 2013 Posts: 10 New Guy | | New Guy Joined: Sep 2013 Posts: 10 | I looked through those specs from 1941-1954. It appears that the 2 ton came about post-war with the first mention of "1 1/2 Ton Special" in 1946 specs. The only explanation of the term I saw was in the 1950 specs (page /5051.htm). This states that the only difference between the 1.5 Special and the 2 Ton is the identification plate showing 15000 max GVW. The plate is an option - RPO 402. I am thinking this must have to do with a government regulation for weight. If I can find more, I'll post it. http://chevy.oldcarmanualproject.com/chevyresto/5051.htm | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 64xx 2.0 ton and 1.5 ton vs 4xxx 1.5 ton truck differences:
One significant difference is GVW:
64xx 2-ton - 16,000 lbs 64xxS 1.5 ton - 15,000 lbs 4xxx 1.5 ton - 4100, 4400, 4500 lbs: GVW 14,000, 14,000, 12,000 lbs
Other spec differences are shown at the link in my earlier post.
You might follow-up with another "why all the different models"?
The simple answer is that GM/Chevrolet obvious saw a market for the various models/differences.
What would be an example of a government regulation for weight (back in the 40s or 50s)? | | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | Some states had vastly different license plate fees based on GVW ratings. When my grandfather's 34 Chevy flatbed trucks and later tractor/semitrailer rigs were hauling beer from Milwaukee and St. Louis to Nashville, negotiating the GVW limits for several states was a nightmare. A legal load in one state would draw an overload fine in the adjoining one sometimes.
It's possible Chevy learned to sell the same trucks with different GVW ratings in different states to take advantage of loopholes in registration fees, hence the ID plate changes. They knew most owners planned to overload 'em anyway! Jerry
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Very nice truck. That single speed rear axle, makes it a 15000lb., special 1 1/2 ton. Commonly the 6000 series trucks came standard with a 2 spd. axle. | | | | | Joined: Jan 2017 Posts: 50 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 50 | Thanks for the replies everyone. I've never had a Big Bolt before but I have fallen in love with them. I think I will get at least one more in the next few years, one with a fifth wheel hitch and trailer to haul the tractor around - might try to find a COE.
Until I buy my own place in the next few years I plan to keep the grain truck at my friend's farm in a barn out of the weather. It may be driven into town for shows but it will also be used for work around the farm, mostly to haul hay or to pick up feed and fencing materials in town.
| | | | | Joined: Oct 2013 Posts: 331 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 331 | What part of Texas are you in?
1950 4100 - unrestored and driven weekly for almost no reason at all.
| | | | | Joined: Nov 2005 Posts: 206 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 206 | HI 58. Fellow eastern tx boy here, I'm 100 plus miles north of you. From your screen name may I assume you own some 1958's or that's your birth yr? I and my truck fleet we're born in 58. Are there any good part sources or junk yards in your area for old Chevy trucks.? I'm always looking for something. Thanks. | | | | | Joined: Jan 2017 Posts: 50 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 50 | Unfortunately there are no good junk yards around here - they crush most cars quickly to cash in on the scrap metal. What few older cars and trucks I've seen are complete rust buckets with few usable parts. The one '52 Chevy I found I took most of the usable parts from 15 years ago, I doubt he has the body anymore at this point - he had to move his junkyard so he probably crushed everything. My user name comes from one of my cars - a 1958 Buick Limited 2 door hardtop: http://www.1958buickforum.net/webpage/58buick.htmI also run the 1958 Buick Forum which is pretty small compared to the StoveBolt forum.
| | | | | Joined: Nov 2005 Posts: 206 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 206 | Best of luck with all your projects. These big bolts r such a challenge. Thanks for writing back. Nice truck ! | | |
