1 members (Samantha),
45
Mod | | | Forums66 Topics128,179 Posts1,057,159 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 127 | How do I get the truck to look like it just came off the showroom floor? I want this truck looking its BEST and I have all the time in the world to work on it. After sanding the pieces down to the metal and putting 2 coats of epoxy primer on it, whats next? What all is involved to get that show room paint look? Can someone give me a breakdown or a good website that shows what all I need to do in steps?
Thanks!
1952 Chevy 5 Window Restoration
| | | | | Joined: Jun 2005 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 128 | | | | | | Joined: Mar 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 127 | Yep, I have no job, plenty of money, and plenty of time on my hands. Whats next?
| | | | | Joined: Mar 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 127 | I mean, I don't need a million dollar paint job, but I want it to be really smooth and really shiny when I'm done.
| | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | I always felt as I was wet sanding as you ran the water over any knick, dent, ding scratch it will show as water is is allowed to fall over. The water will ripple in any area that is out of whack. Lots of filling ,lots of primer. even more time. Did I say patience???? All above will pay off prior any type/kind paint
Dan | | | | | Joined: Mar 2005 Posts: 267 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 267 | blake, do you have a barnes & noble book store near you .i found some books in the automotive section that were very detailed for paint& body in that they had lots of pics and tips. remember there is no such thing as too much info ----------------block sanding  lots and lots
I don't suffer from insanity, I enjoy every minute of it!
| | | | | Joined: Jun 2005 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 128 | Good morning Blake! well your off to a good start with the epoxy,best thing to have on the bottom,cause it stays there.chev46 has a good tip on checking the panel for imperfections,but I perfer to use wax and grease remover in a spray bottle,one of those presurized gardening types.what Im trying to say is after your body work is done primed then blocked,felt oh so carfully with your unemployed hand :p thinking you've got it! spray it with the wax and grease remover and look at it from all angles,different light angles and so on.keep doing this untill you can't find any ripples waves dips scratches etc.start on one panel and finish it!!!! then put it away and move to the next (DO NOT JUMP FROM PANEL TO PANEL)  | | | | | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | Lets see, "showroom" paint for a 52. That would include orange peel, a few "dull spots" where they didn't get good coverage at the factory, and maybe even a run or two and a little trash in the paint. Bob | | | | | Joined: Mar 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 127 | So since I already have epoxy on, can I go ahead and put body filler in places that need it? When do I put my PPG primer on? Does it matter when? I was thinking about doing it in this order: Since it's already got epoxy on it, go ahead and start blocking it, then putting body filler in, then sanding, then more body filler, sanding, sanding, primer, then my base coats if all perfections are fixed. Is this about right? Thanks
| | | | | Joined: Jul 2005 Posts: 8 Junior Member | | Junior Member Joined: Jul 2005 Posts: 8 |
Never read the small print...There is no way you're gonna like it!
| | | | | Joined: Jun 2005 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 128 | Yah thats about right ,except before the base you shoould use a good non sanding sealer that goes on right before you base!  | | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | Originally posted by Blake: Yep, I have no job, plenty of money, and plenty of time on my hands. Whats next? I believe you and I are polar opposites, you see, I have a job, have no money, and no time on my hands. I'll help you w/painting if you help me get into your type of situation.
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Dec 2005 Posts: 33 Member | | Member Joined: Dec 2005 Posts: 33 | Ditto PAKRAT48!  | | | | | Joined: Oct 2005 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 69 | Blake, get a can of cheap spray paint (white primer-black paint) and give your primer a lite mist When you sand any little ding will still have paint and show up. Use a good two part filler followed by a two part spot filler feathering is out about two inches, don,t use a cheap single stage putty. Chean with prep wash, wax and grease remover has solvents which can be soak up in the filler and can cause problem later. I use a 2k urethane primer after that and 2k paint. Jeff
New deal for old steel
| | | | | Joined: Jun 2005 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 128 | Blake what Barney is talking about is (guide coat)this will help you see what you are sanding.Problem with using spray bombs as guide coats is most of them are laquer based,and if not all of the guide coat is sanded off it can cause problems when it comes to painting.I like to use base coat or a graphite powder as a guide coat, both of these are compatable with the paint systems these days.One more thing ,filler will absorbe any moisture, keep all moisture away from filler unless you get some oil or heavey contaminates on an area,wash that area only and dry with air.When filler work is done prime immediately  | | |
