| | | Forums66 Topics128,180 Posts1,057,153 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 142 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 142 | So I bought a very nice thickstun dual carb intake,I'm assuming the intake is aluminum,I also bought a set of original febton headers with the built in heat riser,what a great looking piece.then I thought about heat degrees. How much heat xan an aluminum intake take before it starts to melt.does the chevy 261 produce enough heat to melt the aluminum intake?any an all messages are welcomed. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | No problems regarding cast Aluminum Alloy melting - 650+ degrees C, depending on the alloy recipe. (cast iron would be 1,000+ degrees C)
Cast Aluminum can warp, but that would probably not be a problem once it has been bolted and torqued into place. | | |
