1 members (Guitplayer),
180
Mod | | | Forums66 Topics128,187 Posts1,057,313 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | Broke all the tie rod ends, drag links loose today and what a mess. At least 1/2 were deformed due I'm guessing to rarely getting any grease. The ball seats were worn to about 1/2 normal size. I don't know what was holding it together...think Rust. Tie rod was bent. Good reminder when you buy a 70 yr old truck to do a thorough check on key subsystems before getting out on the highway.
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Good advice, Allen,
Check: tires brake system parts and adjustment (including lines) front end parts and adjustment wheel bearings and adjustment adjust steering change engine oil & filter change gear oil in rear-end and transmission complete tune-up with new all parts battery cable/connections (check for correct gauge if 6v)
That would be a good start. | | | | | Joined: Jan 2017 Posts: 5 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 5 | I have a 1951 GMC 100-22 with a stock 228 CID and three-speed. Truck in family since new. Inferited from father-in-law with the proviso that I would restore. Tie rod is bent, tie rod ends bad. Saw a replacement ad for "Modern" tie rod ends for this application but I can't figure out if they would replace the multi-piece ends or not and can't see how these "Modern" tie rod ends would bolt on original steering linkage? Anybody got any suggestions? Dave | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Others might respond regarding "modern" (sealed) tie-rod ends. Make sure you understand all that has to be replaced and matched-up, if you go "modern".
I use original-style ends/parts and have never had any problems - and, they are adjustable and greaseable.
If the GMC parts are similar to the Chevrolet truck parts (on 1/2 tons, I'd bet they are the same), repair kits and parts readily available (check the "Parts" section in "Links" (upper menu on this page). Full/expensive original-style tie-rod-end assemblies are also available for your size/rear Chevrolet truck. | | | | | Joined: Jul 2014 Posts: 362 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 362 | Allen, was that on the 3600?
I have a couple stock style tie rods and drag links for a 3100 I'm not using.
| | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | Echo, yes it is on the 3600...I would gladly take them off your hands if they will fit. From my read of the shop and assembly manual they should fit. Want to go back with OE. Much appreciated.
