1 members (Hush), 73 guests, and 2 robots.
Topics128,211
Posts1,057,475
Members48,473
SAV
Offline
I've got a 50 3100 with an unusual setup at axle housing/center pivot of leaf springs.
There is a "seat" held onto the leaf spring by u bolts. the seat has rubber bushing running through and is attached to the perch, that is welded to the axle housing, by a bolt running through the bushings.
I cannot find anything referring to or any pictures of this set up. I've got the new shackles and bushings for the ends of the leaf springs and want to replace these obviously worn center pivot bushings while i'm at it.
Is anybody familiar with this?
A photo would help. I'm confused by the 'welded to the axle housing, by a bolt running through the bushing' line.
Give me ambiguity
or give me something else
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1199714/Axle_%22bushing%22.html#Post1199714
Does this thread cover what you are talking about?
Joe
Sav, Joe Apple just posted what I was going to refer you to. What you are describing is the stock setup. You can see pictures in that other thread. That bushing allows movement of the rear end as the springs are compressed and unloaded. Since the torque tube inhibits compression or expansion as the as the springs change their arch this allows for that small movement.
