| | | Forums66 Topics128,209 Posts1,057,462 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2016 Posts: 1 New Guy | | New Guy Joined: May 2016 Posts: 1 | I've got a 50 3100 with an unusual setup at axle housing/center pivot of leaf springs. There is a "seat" held onto the leaf spring by u bolts. the seat has rubber bushing running through and is attached to the perch, that is welded to the axle housing, by a bolt running through the bushings. I cannot find anything referring to or any pictures of this set up. I've got the new shackles and bushings for the ends of the leaf springs and want to replace these obviously worn center pivot bushings while i'm at it. Is anybody familiar with this? | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | A photo would help. I'm confused by the 'welded to the axle housing, by a bolt running through the bushing' line.
| | | | | Joined: Sep 2009 Posts: 123 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 123 | https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1199714/Axle_%22bushing%22.html#Post1199714
Does this thread cover what you are talking about?
Joe | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | Sav, Joe Apple just posted what I was going to refer you to. What you are describing is the stock setup. You can see pictures in that other thread. That bushing allows movement of the rear end as the springs are compressed and unloaded. Since the torque tube inhibits compression or expansion as the as the springs change their arch this allows for that small movement. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | |
