| | | Forums66 Topics128,142 Posts1,056,490 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2016 Posts: 236 DLBrooks | | DLBrooks Joined: Jun 2016 Posts: 236 | Does anyone know if anyone sells new passenger door handle that has lock and key for a 41 chevy truck?
If I have to go to the 42 lock is the 41 passenger latch mechanism different than the 42-46? | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | If no one comes up with the answer for sure I can look, I have both. I tried with no luck to find a new handle for my 41, the way it stands I can not lock the truck. I do know that the door is different on my 46. It will take more than just punching a hole in the door to convert the 41. If it would help you I could take a picture of the outside of my 46 door and you can see the difference. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | The latch mechanism is different on the 42-46 models. 1941 locking door handles show up once in a while on ebay. | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | I was able to buy a N.O.S locking door handle for my '40...which may be same as '41 (the later ones have separate lock in the door.) This was a few years ago but try Cal McCollum in California. He has a lot of old dealer inventory and knows his stuff. 760-723-5134 or FAX 760-723-0907. He was expensive, but I am happy, as I can lock up and go anywhere! And, as mentioned, keep an eye on Ebay. Good luck!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Jun 2015 Posts: 201 Shop Shark | | Shop Shark Joined: Jun 2015 Posts: 201 | I haven't found one, I had my original but it rusted away. I just put regular handles and don't lock mine. Unless you want exact original or live in a bad area I would just put a regular door handle.
... then again I do hope you can get lucky and find one on eBay or something | | | | | Joined: Jun 2016 Posts: 236 DLBrooks | | DLBrooks Joined: Jun 2016 Posts: 236 | Since the truck is titled a 46 and I just put a halfskin on the left door - have not blocked it yet -- I will upgrade. I picked up a 42-46 left door latch on ebay. Then purchased a 42-46 lock and handles. Will make proper hole.
I have a left locking handle with no key and needs replated. | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | The lock goes in the passenger door. If you would like I can send a picture of the door skin on the 46, it is different than the 41. Let me know. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Jun 2016 Posts: 236 DLBrooks | | DLBrooks Joined: Jun 2016 Posts: 236 | Nice trucks -- Thanks for the offer homer52, I have a 42 that I 1/2 skinned and know the location. Thot I would mount the latch and mark the lock square hole as a pilot. Then use the lock gasket for the outline of the hole.
| | | | | Joined: Jun 2016 Posts: 236 DLBrooks | | DLBrooks Joined: Jun 2016 Posts: 236 | Found out today that the frame stamping for a 41 is different than a 42-46. Had to modify door frame to accept the 46 latch mechanism. Going the other way should be no problem. | | |
