1 members (Hotrod Lincoln), 116 guests, and 2 robots.
Topics128,135
Posts1,056,423
Members48,441
DLBrooks
DLBrooks
Does anyone know if anyone sells new passenger door handle that has lock and key for a 41 chevy truck?
If I have to go to the 42 lock is the 41 passenger latch mechanism different than the 42-46?
1959 GMC 100 Fleet
Follow in the DITY
If no one comes up with the answer for sure I can look, I have both. I tried with no luck to find a new handle for my 41, the way it stands I can not lock the truck. I do know that the door is different on my 46. It will take more than just punching a hole in the door to convert the 41. If it would help you I could take a picture of the outside of my 46 door and you can see the difference. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
The latch mechanism is different on the 42-46 models. 1941 locking door handles show up once in a while on ebay.
Lots more pictures
I was able to buy a N.O.S locking door handle for my '40...which may be same as '41 (the later ones have separate lock in the door.) This was a few years ago but try Cal McCollum in California. He has a lot of old dealer inventory and knows his stuff. 760-723-5134 or FAX 760-723-0907. He was expensive, but I am happy, as I can lock up and go anywhere! And, as mentioned, keep an eye on Ebay. Good luck!
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
I
I Offline
I haven't found one, I had my original but it rusted away. I just put regular handles and don't lock mine. Unless you want exact original or live in a bad area I would just put a regular door handle.
... then again I do hope you can get lucky and find one on eBay or something
Stovebolter -- the Next Generation
(I'm 20)
1941 Chevy 1/2-ton pickup
"Lucy"
More pix on Photobucket
1967 Ford Mustang - "Sally"
DLBrooks
DLBrooks
Since the truck is titled a 46 and I just put a halfskin on the left door - have not blocked it yet -- I will upgrade. I picked up a 42-46 left door latch on ebay. Then purchased a 42-46 lock and handles. Will make proper hole.
I have a left locking handle with no key and needs replated.
1959 GMC 100 Fleet
Follow in the DITY
The lock goes in the passenger door. If you would like I can send a picture of the door skin on the 46, it is different than the 41. Let me know. Dave
1941 Chevy
DLBrooks
DLBrooks
Nice trucks -- Thanks for the offer homer52, I have a 42 that I 1/2 skinned and know the location. Thot I would mount the latch and mark the lock square hole as a pilot. Then use the lock gasket for the outline of the hole.
1959 GMC 100 Fleet
Follow in the DITY
DLBrooks
DLBrooks
Found out today that the frame stamping for a 41 is different than a 42-46. Had to modify door frame to accept the 46 latch mechanism. Going the other way should be no problem.
1959 GMC 100 Fleet
Follow in the DITY
