1 members (Hotrod Lincoln), 79 guests, and 0 robots.
Topics128,080
Posts1,055,951
Members48,430
http://s226.photobucket.com/user/46cabover/media/IMG_20141010_102929_735_1.jpg.html
http://s226.photobucket.com/user/46cabover/media/IMG_20141010_102954_790.jpg.html
These are the replacements for Firestone RH-5. Waiting to receive mine. I have not seen any pictures of them on any trucks. Lots of good tech information but are there any pictures of them on trucks and in use.
1946 Chevy 1.5-Ton Flatbed
Photobucket
Old Big Trucks are built to last.
Big Bolt Forum Moderator
looking at the chamfer on the bolt holes, they almost look like stud piloted wheels.
Mike
These are for a different truck not my old Chevy. I don't think they look to bad though.
Photobucket
They look a little strange, and large bolt holes.
1952 Chevrolet 3800 pickup
---All pictures---
Yea these are supposed to be correct for my old ford. Sales man took a picture and emailed me. But they look more like the bolt pattern for my old Studebaker 2r16
Photobucket
$325 each to cut the centers out of the RH5 and weld them into a 22.5" rim. (tubeless)
Photobucket
Photobucket
Crusing in the Passing Lane
Are those new production? Stud piloted, 5 on 8", look nice.
Ed
YES. American wheel specialist of Kennewick Washington
Photobucket
This 5 lug Budd stud centered is not a bolt pattern found on a GM truck.
I've had a couple sets of them original 22.5", out there if you search.
---All pictures---
These are being purchased for my 52 ford f6. However I think the next will be a 1950 Chevrolet 4400
Photobucket
3B Offline
Hy CAJUN CRAW FISH, I am no F@#d expert but I thought they used Budd wheels (stud pilot) as did Dodge. Chevrolet and some GMC used Kelsey wheels (hub pilot) or Motor wheels (hub pilot). The later fifties heavier Chevs and GMCs used Budd wheels. I believe Studebaker used Motor wheels. Wheels of different types with the same bolt pattern usually don't have the same center hole dimension, I believe to alert the installer that something is amiss. If the wheels have mounting holes that are much larger than the studs on which they mount and those holes are chamfered on each side then they are a stud piloted wheel, most likely Budd, hope that helps.
5 on 8" found on IHC.
Ed
These, from american wheel are stud pilot and for my 52 ford. The pictures are an example of the hand holes sent from the sales representative at American Wheel Specialist. You are correct and thanks for the information. Had I not known you would have saved me some cash. As all way's this forum is full of kind folks looking out for the fellow enthusiast. Thanks and God bless you!
Photobucket
I do know that late model Chevy rims in 19.5" will fit the '42-46 1.5 ton (7.25) Chevy pattern but the center (pilot) hole is a quarter inch larger. I made adapters for mine and they bolt right up. Nice to be able to mount some modern tubeless even if they are an inch and a half or so smaller in diameter. I looked for the 22.5's that were on a few mid fifties for two years and finally gave up.
1946 1.5-Ton Chevy Shorty Bus
All my best --- Tango
with the Chevy I will pay the money to have the wheels centers put into tubeless rims.
Photobucket
I have looked into this and the 20" wheel centers I measured were not a good fit in the 22.5" rims, I don't recall exactly what aspect was off but think it was the offset primarily and possibly diameter as well.
At the time I determined that to make/modify/assemble 22.5" wheels for these AD trucks you need the centers from the factory 22.5" wheels from 56-59. Or something different altogether, but not the original 20" wheel centers.
Grigg
---All pictures---
Yep. I had a full set (6) of those ultra-rare 22.5" 5 lug wheels on a 1960 F500 I had a while back. I sold the whole truck for $750. What I shoulda done was scrapped the truck and sold the wheels for about $250 a piece. lol
1950 4100 - unrestored and driven weekly for almost no reason at all.
A gentleman in Prescott, had some, probably 19.5", 10 on 7.25" centers, welded into modern 22.5" wheels, wider than original ones.
Look nice.
Ed
Has anyone had American Wheel Specialist weld the centers from the original 20" split rims into 22.5 outers? Just wonder what they look like.
Grigg
Grigg you are correct in your post above. American Wheel Specialist will weld that difference into the wheel and warranty the wheel. $325.00 each.
Photobucket
Look nice.
Ed
I hope to have good results when I receive my wheels. I communicated the dimensions multiple times and they responded with great confidence over at American Wheel Specialist.
Photobucket
I will try it on the next set for the Chevy. The Wheels I have ordered now are for my Ford and are one of the two types they keep on the shelf for vintage trucks. (Lock ring 20" with tubes) or (22.5" tubeless)
Photobucket
Any pics of the finished product? So they can also weld in to 20" split rings so it should look close to my WM wheels now, shipping must be frightening though. To through that trouble may as well go tubeless...
Stuff I’m gonna work on, I swear
1963 C30 flatbed
1961 Apache 30 (parts, no title)
1960 GMC Big Bolt
Don't tweet, face, Google, or link. Just hanging in as long as I can...
