5 members (Peggy M, Hotrod Lincoln, Gdads51, mick53, 2-Ton), 132 guests, and 4 robots.
Topics128,165
Posts1,056,989
Members48,458
I have read every post on updating tie rods and have learned a lot. I have a 3/4 ton and it has tie rod ball studs with a taper. This means that all updated tie rod ends will not fit in the tapered holes of the steering knuckles. (they fit the 1/2 tons) The 1/2 ton steering knuckles have the untapered holes when the ball studs are removed, but not sure if they are a direct bolt on to the 3/4 ton without changing steering geometry. Does anyone know this information.
At the moment I am scrambling as I disassembled with the thought that the new parts would fit my 3/4 ton. Please help.
Tried NAPA?
Some years of the 3/4 and 1 ton AD trucks already came with "modern" tie rod ends, an improvement from the old type that you can take apart.
Hard to understand your situation as described but wonder if you just need stock replacements for your size truck?
•1952 Chevrolet 3800 pickup
---All pictures---
1954 came with the 2 part tie rods. In reading forums I thought the ball studs were pressed in and I cut them off and one of the original casings is damaged as well. So I could go to the junkyard to find a casing and replacement ball studs. However, the tapered ball studs are hard to find in good shape.
If the steering arm that attaches to the back of the hub is interchangeable between 1/2 and 3/4 ton, I can use the modern ends I already bought with the other steering arm.
The only other options I can think of would be to find a modern tie rod with a taper or to drill out the steering arm to a straight hole and fabricate something like a sleeve to make the modern tie rod fit.
"1954 came with the 2 part tie rods."
The 1954 1/2 and 3/4 ton tie rod was one part (one rod).
Are these the studs you are looking for.
They appear to be the ones. Good find. Now I just need the housing possibly. Thanks.
Which/what housing are you looking for?
The tierod housing which I may get tomorrow at the salvage yard. The one I had was cut down to accommodate a wheel clearance.
So, you have the 3/4 ton, tapered hole, multi-piece tie-rod ends on your truck now, and you bought straight shank, one piece replacement type tie-rods.
Your question is, will the 1/2 ton truck steering arms fit the 3/4 ton truck without effecting the steering geometry? Do you have the 1/2 ton steering arms?
Your options are to replace the ball ends with those listed above in Tim's post and find replacement tie-rod housings, springs, and cups due to yours being cut up and modified. Or, make steel, tapered bushings with straight shank centers to use the parts you bought for the steering arms you have.
Is that about right?
Not mentioned in the option list is ditch the original type and replace with modern tie rod, draglink and draglink ends.
Go to NAPA and see what they offer for your truck.
We're I in your situation, already have steering arms and such with tapered holes, I'd go modern.
---All pictures---
That is right!!!
Thank-you for clarifying for me.
I have a 1/2 ton front clip with the arms, but it is two hours away and was hoping to not drive without some certainty of fit. If they would bolt on my 3/4 ton I would have the straight shank hole and the already purchased updated tierods would work.
Is the taper a common in other tierod ends. Interested to know if anyone has done this and the part numbers.
' Offline
I have a 1954 Chevy 3600. Been in the same place as you are now.
The half ton parts won't work....so forget that idea.
I went GM NOS for a complete front end rebuild.
You need Tie Rod End Studs. You can buy repros if you like.
There is a pair of Tie Rod Studs on ebay right now
GM NOS....$40.00 OR BEST OFFER
Go to ebay & in the search box....type 377992
photo of tie rod studs
GM # 6.243 - GM # 377992
http://i669.photobucket.com/albums/...0NOS/TieRodEndStudsGMNOS_zps2290f318.jpg
You will need Right & Left Tie Rod Shell / Casings
GM # 6.233 - GM # 374226 Right
GM # 6.233 - GM # 374226 Left
There's a pair of Tie Rod End Casings on ebay right now.
Go to ebay & type in the search box: 374226 OR 374227
The seller wants $79.99 OR BEST OFFER
Photo of tie rod end casings
http://i669.photobucket.com/albums/...OS/TieRodEndCasings-PAIR_zpse311a170.jpg
You will also need a tie rod rebuild kit
The GM kit you need is GM # 608840
There are several on ebay now.
Photo of tie rod end rebuild kit
http://i669.photobucket.com/albums/...RodEndRebuildKitGM608840_zps1e1a5908.jpg
The Filling Station , a online parts seller makes a great
replacement kit.....see page 259 of their online catalog.
Photo of: Filling Station Tie Rod kit
http://i669.photobucket.com/albums/...s/Filling_Station_FS-148_zpsf7201a60.jpg
Make sure you keep the old clamps that lock the tie rod casings
to the tie rod.
photo of Tie Rod Clamps - oem
http://i669.photobucket.com/albums/...erseded_to_3902937_b%202_zpsm55j4uww.jpg
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
Thanks for saving me four hours in the car. It is unfortunate that they are not interchangeable.
I appreciate your time on the response. It is a very frustrating issue and I will go NOS. If I can find a casing, I may be able to reuse the innards I have, but need to check closely.
Thanks.
' Offline
Tie Rod Casing GM # 6.233 - GM # 374226 - RIGHT
is available GM NOS
Dan's GM Obsolete
Chinook, Montana
phone: 406-357-2615
Dan's has ( 1 ) - Right Side Casings - GM # 374226
photo of tie rod casings for 1954 Chev 3600
LEFT = drivers side
RIGHT = passenger side
http://i669.photobucket.com/albums/...Rod_End_Fittings_GM_NOS__zps7c0a5e32.jpg
Tie Rod Casing # 6.243 - GM # 374227 - LEFT
is available GM NOS
Colonial Motors
North Branch, NJ
phone: 908-722-2700
Colonial has ( 2 ) Left Side Casings - GM # 374227
Do your own thing your way....but I advise against using the old innards.
The springs have seen better days & I'm sure the ball
seats are worn.
There's nothing like doing the job right with 100%
GM NOS parts.
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
I replaced the tie rod ends on my 59 chevy 36 about a year ago. was fairly simple and cost about $200.00, Found the rod ends at napa and had a new bar built at a speed shop. gained about 1/4 in more clearance between rim (16x6-8 ) and has worked fine since.
' Offline
Do yourself a big favor.
Buy a can of Kroil rust cutter penetrating spray.
https://www.midsouthshooterssupply....penetratinglubricating-oil-13-oz-aerosol
Working on these rusted tie rod ends is very tough.
This spray will make life so much easier.
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
H Online: Content
Forget Midsouth- - - -go right to the source:
www.kanolabs.com
Quite often Kano has a promotional offer that other retailers can't match. I buy KROIL in gallon cans.
So if you read this whole thread you will know that I am trying to fit updated tie rod ends on a 3/4 ton truck. I had wondered if the 1/2 ton steering knuckles arms would fit on the 3/4 ton.
I came across a pair in the salvage yard when retrieving casings to put back the original tie rods. In looking at them and putting them beside the 3/4 ton arms, they looked almost identical except at the ball stud there was a slight size difference on just the end. Anyway, I tried them on and they fit perfectly......and after banging out the ball studs I used the updated tie rods in them since they have the straight (non-tapered) hole. It tracks perfectly down the road after adjusting the tie rod.
This has been a hot topic in many forums and I think this may be a solution to a common problem for 3/4 ton truck owners.
