2 members (mo2cyl, 1 invisible),
200
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2014 Posts: 92 Shop Shark | | Shop Shark Joined: May 2014 Posts: 92 | I haven't been around in quite a while, but I'm putting my truck together (58 Chevy 1/2 ton step-side w granny tranny) and I cant remember where this rod goes. Any ideas? Thanks [image] http://imgur.com/a/sZWeY[/image] | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | It looks like it could be a throttle rod? | | | | | Joined: May 2014 Posts: 92 Shop Shark | | Shop Shark Joined: May 2014 Posts: 92 | Thanks for answering. I'm pretty sure all my throttle linkage is accounted for. This rod appears to be a little heavier that that stuff. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Parking brake release rod? | | | | | Joined: May 2014 Posts: 92 Shop Shark | | Shop Shark Joined: May 2014 Posts: 92 | I didn't know there was such a thing. I wish i could see a pic of the assembly. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The on-line manuals site does not seem to be working. When it comes back up, I'll look for photos/diagrams. RELEASE ROD in this Chevs of the 40s image of GM illustration
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I don't think that illustration is correct for a '58 model. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thanks, cletis.
Is there a parking brake release rod in 1958? | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | It is a shift rod for a column 3 speed shifter. The smooth straight end goes through the "loop" clamp at the top and can be slid up or down till the neutral gate is correct and then the locking nut is tightened.
Evan
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Thanks, cletis.
Is there a parking brake release rod in 1958? I couldn't find a pic of the mechanism but here is a pic that shows the handle running horizontally under the dash to the left of the steering column. I think Evan figured it out. | | | | | Joined: May 2014 Posts: 92 Shop Shark | | Shop Shark Joined: May 2014 Posts: 92 | Would this rod have any application in the 4 speed model that I have? | | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | Looks to me like the parking brake rod the goes from the brake pedal lever to the center connection under the cap floor. There is fork that threads on to that thread end. | | |
