2 members (dt235sd, Southerntruck), 145 guests, and 8 robots.
Topics128,077
Posts1,056,033
Members48,433
#1200135 01/17/2017 10:22 PM
I haven't been around in quite a while, but I'm putting my truck together (58 Chevy 1/2 ton step-side w granny tranny) and I cant remember where this rod goes. Any ideas? Thanks
[image]http://imgur.com/a/sZWeY[/image]
TimBryant #1200139 01/17/2017 10:53 PM
It looks like it could be a throttle rod?
tclederman #1200142 01/17/2017 11:01 PM
Thanks for answering. I'm pretty sure all my throttle linkage is accounted for. This rod appears to be a little heavier that that stuff.
TimBryant #1200146 01/17/2017 11:28 PM
Parking brake release rod?
tclederman #1200166 01/18/2017 1:24 AM
I didn't know there was such a thing. I wish i could see a pic of the assembly.
TimBryant #1200186 01/18/2017 2:58 AM
The on-line manuals site does not seem to be working.
When it comes back up, I'll look for photos/diagrams.
RELEASE ROD in this Chevs of the 40s image of GM illustration
TimBryant #1200221 01/18/2017 7:09 AM
I don't think that illustration is correct for a '58 model.
TimBryant #1200229 01/18/2017 1:13 PM
Thanks, cletis.
Is there a parking brake release rod in 1958?
TimBryant #1200249 01/18/2017 3:59 PM
It is a shift rod for a column 3 speed shifter. The smooth straight end goes through the "loop" clamp at the top and can be slid up or down till the neutral gate is correct and then the locking nut is tightened.
Evan
tclederman #1200258 01/18/2017 4:57 PM
Thanks, cletis.
I couldn't find a pic of the mechanism but here is a pic that shows the handle running horizontally under the dash to the left of the steering column.
I think Evan figured it out.
coilover #1200262 01/18/2017 5:41 PM
Would this rod have any application in the 4 speed model that I have?
TimBryant #1200286 01/18/2017 8:46 PM
Looks to me like the parking brake rod the goes from the brake pedal lever to the center connection under the cap floor. There is fork that threads on to that thread end.
