7 members (EchoBravoSierra, WICruiser, 55Delray, Steve L., Bill Hanlon, MickeyP, 1 invisible),
71
Mod | | | Forums66 Topics128,206 Posts1,057,435 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 69 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 69 | It has been a long time since I posted on this forum. After a long pause, I have decided to make the final push and finish my truck. To help fellow truck restorers in the future, I will document everything I do in pics (even the screw ups). Here is my restoration blog: http://1942chevy.blogspot.com/The two older boys in the blog are now Sophomores in College. Where does time go? | | | | | Joined: Jun 2016 Posts: 236 DLBrooks | | DLBrooks Joined: Jun 2016 Posts: 236 | Cool, is it a 42 or a 45, no differences that i know of. I have a 42 1/2 ton rod and a 46 3/4 ton I am working on now. I see you are in Ohio also and have been a member of this forum for a while. Will your truck be completely stock when finished?
| | | | | Joined: Jan 2009 Posts: 69 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 69 | The truck was titled as a 42 but it was made in 45. I will keep it as stock as possible. I will keep the original war parts painted. Almost went with chrome handles but I am going to use the old bakelite ones. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Jeff, Progress is looking real good. I've seen a couple war era trucks, had lots of unique parts. Best of luck Jim | | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | Nice pics, I am also from Ohio I am on the south end of I77 ,below Marietta. I have a 46' that I have been making a push to get much more done this winter. I am hoping to get the engine started before spring. I have made some good progress in the last month. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I have a couple grille pieces that are just painted, '42 production, since there was little war production, everything not registered in '42, was titled '45 after the war.
Ed
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Jeff,
Nice to see you are back to your restoration. Your project is looking good.
It is my understanding that only one of the nine Chevy assembly lines continued to produce civilian trucks (no cars) during the war. Pick up trucks were much less common than larger trucks.
Paul | | | | | Joined: Jan 2009 Posts: 69 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 69 | If memory serves, this one was made in Norwood, Ohio. | | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | Jeff, welcome back, truck is looking good. I am working on a 41 1/2 ton and hope to have it on the road by the Spring.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
| | | | | Joined: Jun 2016 Posts: 236 DLBrooks | | DLBrooks Joined: Jun 2016 Posts: 236 | I look at craigslist occassionally for parts across Ohio, W VA and Kentucky so we probably look at the same parts. There was a 45 all body no frame with title in Washington Court House a while back that was stripped stored inside and was a good buy. Just about made the leap --just because it was a 45 with all good body parts. But I have a 42 and 46 ----haha.
The 46 I have needs a (54 235) valve job and some lifter attention, maybe cam, but it starts and drives.
Last edited by cletis; 01/20/2017 6:52 PM. Reason: Deleted veiled part offer/wanted request
| | | | | Joined: Oct 2012 Posts: 60 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 60 | I'd like to hear how you got your new headliner installed. Fiberglass one piece? Two piece cardboard? I have 46 GMC and my first headliner install did not go so good. | | | | | Joined: Jan 2009 Posts: 69 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 69 | I put in the two piece cardboard headliner.
It was definitely a two person job and I remember it was a bit of a pain, but it looks good. | | |
