2 members (Hotrod Lincoln, Hush), 58 guests, and 4 robots.
Topics128,021
Posts1,055,355
Members48,420
#1198918 01/08/2017 6:06 PM
This is on my 46 chevy, does anyone have a picture on the mounting bolts and spacers for the radiator support bracket / frame
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
Are you talking about the mounting bolts holding the radiator support to the frame or the "V" brace to the firewall?
Harold
Harold
Did some clean up work a few years back on someone else's paint and assembly work on a 36 GMC. One item of note was that the core support spacers was so far off that the hood sides overlapped the cowl. Look through this link, it's how I addressed it. It wasn't a stock repair, but it was functional.
http://www.garagejournal.com/forum/showthread.php?t=106178
I am talking about the spacers, if there are any , and connecting the support to the frame. I was trying to avoid the wrong height issue with the rest of the front clip.
1946 1-ton Panel
I don't have a picture I can find as I lost a bunch when Webshots closed down. However I used a 3-3 1/2" carriage bolt from the top down thru a 1/8" rubber piece, 1/8" plate steel, both drilled to match radiator support thru what I think was valve springs, another 1/8 rubber into crossmember. This was what I removed other than the rubber mounts which I cut out of vinyl baseboard. You still may have to adjust up or down to to fit front assembly. Hope this helps. Have fun and good luck
Dan
I think I recall, someone posted a link several months ago showing the installation and sequence of bolts, washers, springs, rubber cushions, and nuts. Maybe a search here in the Stovebolt will yield the info?
Mike
Check your email. I just sent you some photos showing the sequence of hardware installation.
