8 members (msmall, 68ironhead, Shardean, DannyW, Eisenholtz, 3800GUY, Shade Baby, cmayna),
41
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | This is on my 46 chevy, does anyone have a picture on the mounting bolts and spacers for the radiator support bracket / frame
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Are you talking about the mounting bolts holding the radiator support to the frame or the "V" brace to the firewall? Harold
Harold Is a restoration ever finished? | | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | Did some clean up work a few years back on someone else's paint and assembly work on a 36 GMC. One item of note was that the core support spacers was so far off that the hood sides overlapped the cowl. Look through this link, it's how I addressed it. It wasn't a stock repair, but it was functional. http://www.garagejournal.com/forum/showthread.php?t=106178 | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | I am talking about the spacers, if there are any , and connecting the support to the frame. I was trying to avoid the wrong height issue with the rest of the front clip.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | I don't have a picture I can find as I lost a bunch when Webshots closed down. However I used a 3-3 1/2" carriage bolt from the top down thru a 1/8" rubber piece, 1/8" plate steel, both drilled to match radiator support thru what I think was valve springs, another 1/8 rubber into crossmember. This was what I removed other than the rubber mounts which I cut out of vinyl baseboard. You still may have to adjust up or down to to fit front assembly. Hope this helps. Have fun and good luck Dan | | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | I think I recall, someone posted a link several months ago showing the installation and sequence of bolts, washers, springs, rubber cushions, and nuts. Maybe a search here in the Stovebolt will yield the info?
| | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | Mike Check your email. I just sent you some photos showing the sequence of hardware installation.
