2 members (Otto Skorzeny, TexasFarmTruck), 83 guests, and 5 robots.
Topics128,269
Posts1,058,399
Members48,485
Junior Member
Junior Member
I'm thinking that I may try taking out a 1 1/2" section of the hood to lower it, is there a write up or how to article on doing this or has anyone done this before?
hey Nerd - never seen it done and haven't heard of anyone doin it, but I've considered it - might look neat to take a bit outta the front to reduce that bald-forehead look, but you wouldn't be able to do an even sectioning, hafta taper up to stock at the back - looked like too much work to me - you get to write the how-to, take lotsa pics and let us know if ya pull it off grin
Junior Member
Junior Member
They did it on Overhaulin with the yellow truck (don't remember the year).
I have seen many "pie cut hoods." If I understand it correctly, you would take 1 1/2" of material out of the front of the hood and taper the cut back to 0" at the rear of the hood. To take 1 1/2" out of the whole length of the hood it would require modifications to the firewall and cowl so that they all meet up correctly. Does this make sense?
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
I would have to agree with Phil, sounds like a piecut would be your best bet otherwise your cowl is going to be a couple inches higher than your hood. The pie cut isn't as easy as it sounds unfortunatly. The steel has memory, which simply means when you cut the middle of the hood it will try to return to being flat. This is because when the metal is stamped it is forced to remain bent by the other features of the hood, the body lines and folded edges. When you cut the hood, the tension will be released and the curves will slightly flatten out. So when you try to re-connect the two halves there will be a width difference across the hood. The way around this is to weld a brace to the hood in several places approaching the cut line as close as possible. This will minimize the amount the hood is allowed to flex and will help you to realign the two halves. After you get the pieces back together, simply remove your braces...
Need more space for VEHICLES in the list area! Maybe I just need to thin the herd...
Junior Member
Junior Member
Thanks for the replies, I think the 1 1/2" pie cut with the braces accross would be the best solution, how would you keep the back of the hood in perfect alinment with the firewall?
Once you start lowering the top have of the hood to the bottom I would think that the back would start bending forword and out of line with firewall.
Socket Breaker
Socket Breaker
http://www.hotrodders.com - would be a great place to look for that kinda information. smile
I'm not trying to run you off but that is their cup of tea for sure.
-W
