1 members (2-Ton),
133
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,114 Posts1,056,287 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 90 Shop Shark | | Shop Shark Joined: Jul 2009 Posts: 90 | The insulator block broke on my 1957 235 that goes between the carb and intake. It's like a cork-feeling material. Should a regular gasket be used with this? Is there anywhere is preferred to get a replacement? I don't want to waste time and money on a cheap product.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | "quark-feeling material" (no joke: what does this mean?) I think it was bakelite type of material? carburetor insulator (wider opening for later 235s and 261s) Use an gasket on top of the insulator (a gasket not needed under the insulator if the mating surfaces are flat and smooth - not pitted). | | | | | Joined: Jul 2014 Posts: 362 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 362 | "quark-feeling material" (no joke: what does this mean?) ... Cork? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Good guess, EBS - you are probably correct.
I do not think that cork would work well in this application? | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Quark? Don't think I have heard that term since college physics  Somehow, there must be another meaning; I cannot really associate sub-atomic particles with a stovebolt 6. All joking aside: Vetteman, the originals were sometimes bakelite, sometimes a fiber compound, and aftermarket versions were often make by cheaply laminating (read as fastening together with long staples!) a number of asbestos flange gaskets to the required thickness. Often, enthusiasts machine them out of a block of hardwood, and just as often paint the edges black. Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Jul 2009 Posts: 90 Shop Shark | | Shop Shark Joined: Jul 2009 Posts: 90 | Sorry guys, I meant cork. I also study particle physics as a hobby and quark and cork are pronounced very similarly and I made a mistake when typing since I have recently been reading a lot about "quarks".
What I meant was it felt as though it was a "cork type" material, being that its composition was hard, but soften than metal. As carbking said, "Fiber compound" would have been a better description. I ask because I also saw the product for sale that Tim gave the link to and the description doesn't give the material form which it is made. It appears to be some type of plastic and I don't want to waste money on something that won't work correctly. We all know how many "gasket" type parts are made cheaply and ineffectively, like for example the cheap plastic intake manifold gaskets for 5.7 Chevrolet Vortecs which fail almost before you put them on. I'm aware this isn't a gasket but it does connect two flat surfaces of metal. | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Vetteman - Cork is much too soft, and will not work. Quark on the other hand......how many would it take, and how do you pick one up?  The spacers are probably available or see my first post for suitable materials you can use to make one. Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | All the 47-55/etc vendors sell them (link to Classic Parts in post above, and Chevs of the 40s, Filling Station, etc.) mod edit : Links see a preferred vendor near you, under the Parts section.
| | | | | Joined: Jul 2009 Posts: 90 Shop Shark | | Shop Shark Joined: Jul 2009 Posts: 90 | I guess what you guys are saying is that all the products offered are relatively the same and are good for their purpose.
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 |
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Everyone suffers from typing the wrong word on occasion. It's also common for light hearted teasing to occur when that happens. Let's all get a sense of humor. I was notified about a 'rant'. I don't know if it met that criteria but the question has been answered so the thread is locked. The forum Mods can unlock if they deem it necessary.
