1 members (Hotrod Lincoln),
60
0
Mod | | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2015 Posts: 47 | Hello All, I recently started to prime my 54 235 after rebuild in anticipation of the first start. Unfortunately, as soon as my gauge started to read about 45psi, the Fram bypass filter began to leak out of the top where the wingbolt goes through the lid. I changed the O-ring and even added one so there is an o-ring on the inside and outside of the lid where the wingbolt comes through, but still leaked oil. Has anyone had any experience with this and/or recommend the correct o-ring and location (inside/outside)? Thanks,
Nico | | | | | Joined: Feb 2004 Posts: 29,767 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,767 | Use a soft copper flat washer between the wing nut/bolt and the lid. It will seal much better than an O ring. Don't be afraid to tighten it firmly- - - -those things are hard to seal. Jerry
| | | | | Joined: May 2015 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2015 Posts: 47 | Thanks Jerry, any 0-ring or other seal on the inside of the lid where the bolt comes through? | | | | | Joined: Feb 2004 Posts: 29,767 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,767 | Unless there's a counterbore for the O ring to fit into, it will do nothing in the way of sealing. Does the standpipe or the cover have a groove for the O ring to fit into? Jerry
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | For another potential fix. Mine came with an inverted cup shaped washer at the top with a rubber material in the 'cup' to provide the seal. The rubber had turned hard. I bought a rubber washer at the hardware store to replace the old hard rubber. It seals just fine. I can't say it came new with that setup but it works for me. This is mine.
| | | | | Joined: May 2015 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2015 Posts: 47 | Well I'm not sure which fix did it, but I stopped the leak. I put a flat washer and a copper washer on the wingbolt outside the filter, and a fat rubber o-ring on the inside of the lid. No leaks from the filter on the next priming run!! Unfortunately, the swivel adapters that came with the oil lines BOTH leak, but this seems like a simpler fix - replacements on the way.
Thanks everyone! | | |
